It is currently Tue Aug 19, 2025 5:30 am
 Post subject: Wheel Cylinder Problem
PostPosted: Sat Sep 07, 2013 4:40 pm
Well thought i'd fit my new wheel brake cylinders today and have come up with a bit of a problem , the holes dont line up with the new cylinders .
So do i just file the back plate to fit as ones way out and the other is slightly out?
Day didnt start well either bought some new grease and a kinchone grease gun , decided to make sure grease would get to the ball joint socket " it did " ..... so i put the grease gun on the grease nipple and.................. the bloody thingy wouldnt come of so i used a bit if muscle to pull it off and the top of the grease nipple snaps off in the tip of the gun ...arrrgghhhh .
Whay a freakin day.
Cheers Bill
PostPosted: Sat Sep 07, 2013 5:26 pm
Yea just rip in with a file, fairly common problem
PostPosted: Sat Sep 07, 2013 5:32 pm
I read somewhere it needs to be filed out, unsure where I read it? I think it was when upgrading from 15/16ths to 1 inch.
Are these the 1" cylinders?
For memory mine did fit and I was surprised I didn't need to do any mods!
I recently upgraded the fronts to discs and the rear cylinders to 5/8ths and was surprised when they fit without mods as well.
Justin
Justin
PostPosted: Sat Sep 07, 2013 6:47 pm
Thanks mmm & Jubblies , they are 15/16 they were the ones karcraft recomended for my model part #GWC126 & 127 " 73 clubby " so i will just file them out then , bit of a pain but what can you do " hopefully the rear ones fit without any mods".
Cheers Bill
PostPosted: Sat Sep 07, 2013 10:01 pm
You can get the back plates from karcraft for the 15/16 wheel cyl i changed mine cause one adjuster was loose and kept slipping
There is post on here about the holes a few weeks ago
viewtopic.php?f=2&t=82438
Another one of your threads bill page 2 read what karcraft wrote
Mg spares at smithfield sell 1' wheel cylinders thats where i got mine from before i realised the adjuster was stuffed on passenger side
PostPosted: Sun Sep 08, 2013 10:36 am
Thats rather disapointing then as Karcraft were the ones telling me which wheel cylinders i needed for my 73 mini and reading that post he says from 74 onwards they were 15/16 ..... damn not sure what to do now as the back plates are over $100 each and dont need replacing anyway ..... arrrggghhh .
Edit : I will ring Karcraft tomorrow and organise an exchange.
PostPosted: Sun Sep 08, 2013 11:57 am
Our previous post.
There is nothing wrong with the wheel cylinders.
In about 1974 Leyland changed the stud pattern and backing plates when they introduced 15/16" wheel cylinders to replace the 1" wheel cylinders.
To stop people replacing a 1" cylinder with a 15/16" cylinder Leyland changed the stud pattern slightly. This was a safety measure.
People are too quick to always blame the replacement part.
If fitting the latter 15/16" cylinders to a 1" car all you have to do is slightly elongate the hole in the backing plate. Using a round file it will take about 1 minute to do.
This slight modification has been around for over 30 years so it is not new !
Hope this helps.
PostPosted: Sun Sep 08, 2013 12:46 pm
Karcraft wrote:
Our previous post.
Hope this helps.
Thanks for the reply , i will do the mod then
Thanks again for not only the help with the parts i needed but also with the fast shipping and the after sales help on these forums , its greatly appreciated.My next order for my windscreen seals etc will be in soon.
Cheers Bill
PostPosted: Sun Sep 08, 2013 6:26 pm
I have now done this mod to all my drum brake minis. I usually use a dremel, much quicker than a file :wink:
The rears have never been a problem, only the front.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Sep 08, 2013 6:47 pm
I was the other way round fitting 1' cyl to 15/16 backplates so i just went back and got some 15/16 cyl cause every thing was coming out to do the oil seals and inner cvs at the time
PostPosted: Wed Sep 11, 2013 9:17 pm
Modded the backplate and the cylinders fit fine " had a harder time putting the spings and shoes in :-)" .
Thanks all
Cheers Bill
Users browsing this forum: No registered users and 266 guests
