It is currently Fri Jul 18, 2025 11:12 am
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue Nov 09, 2004 9:15 am
Don't know of many 2 stroke Dukes :roll: but the best could possibly be a Triumph (Hinkley) triple - English & good sound, plus loadsa power. Noisy cabin though, better fit some whopppin' subs
PostPosted: Tue Nov 09, 2004 10:43 am
why wont the v8s turn a corner?
PostPosted: Tue Nov 09, 2004 11:00 am
MiniK wrote:
Dont you mean 1600......all the 20V Toyota Engines i know are 1.6L. Silvertop's from the AE101's and 92 Corolla Family and Blacktops from AE111's were all 1600.
If your putting one of these things in Id love to see how it fits.....cause to me theyed be WAY too big for a mini.
Id think a 4AGE would be better suited...SFA difference really in power between them.
I'm a bit of a closet Toyota nut...
All 1600cc:
4AGE 16V(early) 88kw with TVIS
4AGE 16V (late) 100kw no TVIS
4AGE 20V 115kw?? no TVIS
4AGZE 16V 125kw?? Supercharged
TVIS had two throttle bodies - small one for low rev torque, large one kicked in at higher revs for more breathing.
All look a bit big to fit in a Mini, especially the gearbox. But then a Starlet EP82 looks a bit big too....
Cheers.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Tue Nov 09, 2004 3:07 pm
I reckon the 4age's are too wide, 90cm is about the limit for engine + gearbox... I reckon the SR20 would fit better, I measured one up, but might have to be a clubman as it's pretty deep if you keep the turbo where it is - I'll build one after I'm done with the honda :twisted:
PostPosted: Wed Nov 10, 2004 12:00 am
Bahahaha
Oh! i had better not disclose the plans for my final mini project then....... lets just say the wheels are not going to fit inside the body...... and thats the way i'd like it :wink:
And also...... I am another person here who is guilty of spending MUCH time and money on Toyotas.... here's what i learnt...
There were many different versions of the 4A-GZE supercharged motor, the earliest version had 135hp in standard form, the latest version had 180hp in standard form. Parts from the later version wont fit on the early motors due to internal redesigning.
Here are a few interesting upgrade, using an early supercharged motor (4A-GZE), and then a naturally aspirated motor (4A-GE) as examples.
1988 & 89 Toyota MR2 - Supercharged (4A-GZE Engine)
Stock (145 hp @ 8 psi)
Stage 1: (151 hp @ 8.5 psi)
+Supercharger Exhaust System
Stage 2: (161 hp @ 8.75 psi)
+Power Flow Air Filter
+Twin Power Ignition
Stage 3: (180 hp @ 10 psi)
+Oversize Crank Pulley
Stage 4: (188 hp @ 10 psi)
+Camshafts & Cam Gears
Other upgrades:
-HKS Twincharge kit (A turbo and a supercharger on one motor) - 250 to 300 hp is to be expected.
1985 to 89 Toyota MR2 - Naturally aspirated (4A-GE Engine)
Stock (112 hp)
Stage 1: (118 hp)
+Sport Exhaust System
Stage 2: (128 hp)
Stage 3: (138 hp)
Stage 4: (170 hp)
+Stroker Kit (Does not work for all years)
Other upgrades:
- Bolt on turbo kit from Blitz - claimed 305 hp is to be expected.
Last edited by supercharged 850 on Wed Nov 10, 2004 12:40 am, edited 1 time in total.
PostPosted: Wed Nov 10, 2004 12:26 am
Oh..... and i hate to ruin the party, but there IS a 1.8 litre 16 valve Toyota motor.
Its called a 7A-FE. Is basically a 4A-GE motor with a longer stoke and different head. The internals are weaker than those in a 4A-GE, and the head doesnt flow too well. The easiest upgrade is to change the head for one off a 4A-GZE....... 10 hp can be gained just from this.
With this mod, the 7A-FE is now a hybrid motor, technically you could call it a 7A-GE.
NOW, take all the supercharger gear from the 4A-GZE, bolt it to your hybrid motor, and it can be called a 7A-GZE.
Both 7A-GE's and 7A-GZE's are combinations that were never produced by Toyota, but can be built at home.
PostPosted: Wed Nov 10, 2004 7:52 am
Spent too much time and money modding Geminis and quite a bit of time and other people's money modding Toyotas.
Planning a Toyota Corona Hardtop project of my own, when I find the right bodyshell. 8)
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Sat Nov 13, 2004 10:36 pm
supercharged 850,,,they were discussing the "20Valve" 1800 cc thing, not the 16valve type,,,
& i`m no toyota nut, but i have actually helped build/creat an 1800cc, 20valve toyota donk for a friend of mine at Taylor St mechanical , in Brisbane here,,,his name is Greg Craig & his work phone number is (07)3399 6469
if you`re interested in knowing how to do it
easy-peasy
& to anyone else who mentioned that the V8 mini might not turn,,,you obviously don`t know me very well hey???...i`ll make it turn, don`t you worry about that,,,everything i do in this world i do with performance handling involved :-) seriously!!!, ,,,have you ever thought about a front wheel drive yamaha R1 powered Go-Kart????????????? yeah!!!!!!! it`s a happening thing!!!!! 150hp & 70kgs added to the front of a go-kart, & then i just sit my fat 85kg ar$e on the back of it to equal things up a bit :-)
again,,,easy-peasy
PostPosted: Sun Nov 14, 2004 9:31 am
Not a bad power weight ratio there mate :twisted:
i think with all the conversions going on at the moment or just beginning the next few years of the mini scene will be an interesting one here in oz
PostPosted: Sun Nov 14, 2004 8:13 pm
hey on the v8 topic check this page out the RED VAN half way down
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: http://www.minimania.com/web/threadid/6 ... thread.cfm
PostPosted: Tue Nov 16, 2004 4:05 pm
i'm still down with the 1.4L k series twin cam. just found that there's a Variable Valve version too :)
honest and brittish to boot :)
 Post subject: Toyota motor
PostPosted: Wed Mar 02, 2005 7:42 pm
True... but in SA we ge t the black top Toyota motor. 1800 RXI 20valve with a auto gearbox. Just drop the gearbox and go for manual. Change the computerbox to something like mrTurbo EFU. (SA)....
Anyway.... The Backwheel drive conversion for my rotory turbo is almost complete. Car was standing fo a year. Been working on it for 1 month everynight. Body now one with the manta suspension. Also build the firewall etc. Cut the manta dasjh and fitted that aswell.... Will fibreglass this.
Will post pics again. Was offline for a while.
Isssh - where did my avitar go?...he he :lol:
PostPosted: Wed Mar 02, 2005 10:25 pm
HAHAHAHAHAHAHAHAHAHAHAAAAAAAAAAAAAAAAA :lol:
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Thu Mar 03, 2005 10:23 am
now now... no need to start stuff ;)
PostPosted: Thu Mar 03, 2005 11:10 am
i just thort it was funny.thats all
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
