It is currently Fri Jul 18, 2025 10:33 am
 Post subject: Mini Starter Problems
PostPosted: Tue Dec 21, 2010 3:47 pm
Hi all,
Im having problems with my mini starting. It has a weber on it, and it used to start fine. However I changed the head gasket, now the starter disengages every time I try to fire it up. The guys at minisport said the weber causes this, my question is why and how do i stop it. I dont really want to put a $500 starter motor on the car as im just trying to get it registered so I can sell it.
Brendan
PostPosted: Tue Dec 21, 2010 4:42 pm
Mods rock!
Possibly the ignition timing is a little less than optimum for starting, usually a little to far advanced. Where it is might be right for driving, but maybe not for starting.
PostPosted: Tue Dec 21, 2010 6:31 pm
After breaking teeth off 3 or 4 Lucas starter pinions with my modified 1360, I put a separate switch on the ignition circuit. I spin the starter up with ignition off, then throw the switch ON. Works for me...:mrgreen:
[edit] You could fix your problem by replacing the starter with a pre-engaged one. A modified Holden Gemini one is available from Heritage MG parts which bolts straight into an early Mini (not Rovers). Cost ~$162.
http://www.mgspareparts.com.au/index.ph ... &Itemid=26
You could go buy one S/H from a wrecker, but would need to slot the mounting holes to fit a Mini.
PostPosted: Wed Dec 22, 2010 8:05 am
Yeah I did wonder about the timing...i'll try retarding it a little bit but if that doesnt work the gemini starter sounds pretty good.
Minis are awesome cars once you take all the british bits out of em.
Users browsing this forum: No registered users and 27 guests
