It is currently Sun Jul 27, 2025 9:16 pm
 Post subject: Some gaugaes not working
PostPosted: Sun May 29, 2005 5:50 pm
I have a clubby three guage setup with a tacho.
Driving today i noticed that the center guages have stopped working. Not all things have stopped. Blinkers still work, dash lights still work. But i have no fuEL, TEMP and alt light. I didn't check the high beam but i have a feeling it won't work either. I have checked the fuses. and checked to make sure the connector on the back is in nice and tight. Someone said today that there is a regulator in the back of the guages. but i don't know where that would be in a clubby, if they have one at all? Any clues anybody?
Aaron
PostPosted: Sun May 29, 2005 6:20 pm
It's a 10V regulator, like on a roundnose, but on a Clubbie it plugs into the PCB. 99% chance that's the problem. When they go, the gauges either read high, or zip.
PM Wombat, he makes electronic ones for $15 or so. :wink:
PostPosted: Sun May 29, 2005 6:23 pm
There is a silver-colour voltage stabiliser in the back of the guages. Its rectangular and has three pins. I think I need a new one too...
Check the printed circuit board thouroughly, too. If there is a break in any of the circuits, they should be fixed. Don't do what most people do and use a soldering iron. You end up just buckling/melting the plastic. Buy yourself a conductive pen ($35 from Dick Smith's) and just redraw the circuits. It sounds expensive, but it lasts for ages, doesn't melt the plastic, and is good for overclocking your X800 Pro graphics card! :wink: Just remember to scratch away at the surface lightly to break through the plastic coating and expose some copper, then join the two exposed spots.
Jonathan
PostPosted: Sun May 29, 2005 9:05 pm
someone else on here had this prob and the majority of responses said 'printed circuit'
PostPosted: Mon May 30, 2005 10:17 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
arron it is below the speedo on the back it is a silver oblong it is a tight fit but will come of with persation
makka
PostPosted: Mon May 30, 2005 10:19 am
Thanks guys i will pull it out and pop it back in tonight and see if that fixes it. if not i will try a new one from wombat. or get another guage to test whats wrong with it.
Aaron
PostPosted: Mon May 30, 2005 5:44 pm
We have a winner. And to top it off i snapped the speedo drive today too! :oops:
Aaron
PostPosted: Mon May 30, 2005 5:57 pm
i love it when things just work out
Expert in training
PostPosted: Mon May 30, 2005 6:44 pm
I can't quite see what the problem was from the photo?
Glad it is sorted anyhow. KB
PostPosted: Mon May 30, 2005 6:52 pm
just left of the earth lead there is a copper track lifted and broken. I also found another crack in the dash light track that serviced the tacho. i was wondering why it worked and didn't. Anyway i will have that all fixed and back in tomorrow moring, but i am not climbing under the car to swap speedo cables in the cold weather! it can wait.
Aaron
PostPosted: Mon May 30, 2005 8:12 pm
for those interested. i have fixed the PCB and also was able to thread a new speedo cable into the old surround. (it had snapped at the head end.) works a treat and now i can see that i need to fill up before i go to work tomorrow morning. :oops:
Aaron
Users browsing this forum: fuzzy-hair-man and 84 guests
