It is currently Sun Jul 27, 2025 10:41 pm
PostPosted: Mon May 30, 2005 5:49 pm
You guys, it's called sarcasm!
PostPosted: Mon May 30, 2005 9:37 pm
yeah how many times you gotta point it out? :roll:
PostPosted: Mon May 30, 2005 9:43 pm
twas only on the passenger side
and you bunch of idiots, i was being serious
Inconspicuously Conspicuous
PostPosted: Mon May 30, 2005 10:40 pm
CRU17Y wrote:
IM puzzled,
Are you saying not too get disc brakes cause the drums are better, im confused
Mick, CRUI17Y was still confused, so i thought i'd have a go :lol:
asif dook..you know you want 'em.. :mrgreen:
PostPosted: Mon May 30, 2005 10:47 pm
Is that grease?
Or bubbled brake fluid?
Freakin dangerous whatever it is.
Looks like the wheel cylinder has pulled an absolute shitter.
PostPosted: Tue May 31, 2005 12:18 am
what do you get if you mix 30 yr old brake fluid with 30yrs worth of brake shoe dust
"a wheel thats pulled a shitter"
you said it Will :wink:
you wouldnt have known if you drove it. pulled up very nicely, some of the wheels would even lock up if you pressed hard enough, and we're talking about drums here
PostPosted: Tue May 31, 2005 7:32 am
Looks like a candidate for some new wheel cylinders, brake shoes and check the drums..
Hmmmm... wonder what the rears are like.. :lol:
Fix 'em properly & they'll last another 20 years or so!
PostPosted: Tue May 31, 2005 1:04 pm
i havent gotten to the rears yet :oops:
if the drums are buggered would they need maching or would i need to seek out newies
PostPosted: Tue May 31, 2005 1:07 pm
depends how far out they need to be machined... 60 thou is probably the limit. I had problems with machined drums when I had them on my K, I had to buy oversize shoes and couldn't adjust them far enough to use up all of the pads
PostPosted: Tue May 31, 2005 7:52 pm
If drums need machining take them to a brake shop, the shoes too. They will supply rebonded shoes with oversize linings, ground to match the machined drums. There are 2 std oversizes- + 1/32" and + 1/16".
Never try to use standard shoes in a machined drum- it doesn't work. By the time they are bedded in they are worn out. :cry:
PostPosted: Tue May 31, 2005 9:21 pm
Jesus Duc when I said to try and make your Moke go faster i ddint mean screw up the brakes..!!
My advice would be to replace the lot. Just did that on the van as apposed to having the drums machined and oversized shoes put on as on the sedan, and the van stops in half the time the sedan does...
After driving the van with discs on though, I am still collecting loose change from the back of the couch until I can get some discs for Mo... :wink:
PostPosted: Tue May 31, 2005 9:43 pm
Thanks marc
yes replacing all the old bits does sound appealing
especially when dealing with safety.
dont mind give Heritage a bit of good business if it means newie everythings
PostPosted: Tue May 31, 2005 9:45 pm
let me know what they quote, I can tell you what I got mine for.
:D
PostPosted: Tue May 31, 2005 9:46 pm
i will.
gotta check out the condition of the existing ones first...
when i pull my finger out :wink:
PostPosted: Tue May 31, 2005 9:47 pm
"... A little ray of sun shine......"
A little ray....
:wink:
Users browsing this forum: Bing [Bot] and 86 guests
