It is currently Sun Jul 27, 2025 10:40 pm
 Post subject: Warped Brakes
PostPosted: Mon May 30, 2005 8:30 pm
I think the run through the OPH to Terrigal warped my disk brakes!! :?
Cant believe ti! :evil:
~*~ ThE SOR53Y PrInCeSs in MERLIN the MIN-WAH!;)~*~
*~* cruising in an EVO 6.5 TME as well! :D*~*
PostPosted: Mon May 30, 2005 8:32 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i doubt that would happen maybe the bearings need a tighten what are the simptoms sorcy ??
makka
PostPosted: Mon May 30, 2005 8:38 pm
Yeah, I'm with Makka, never seen discs warp from normal use
PostPosted: Mon May 30, 2005 9:09 pm
well my shagn wagon daily hack had warped discs....it's an auto and I am heavy on the brakes......I had to replace them. $220 new....or $25 second hand :wink:
I say if you ride your brakes you can warp them!
PostPosted: Mon May 30, 2005 9:26 pm
Trick question...... How do you know that they were warped? Did you measure the runout with a dial gauge?
PostPosted: Mon May 30, 2005 9:33 pm
i heard u can warp discs by putting on the hand brake when they are hot. mind u that was from a ricer........
PostPosted: Mon May 30, 2005 9:41 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
mini's dont have disk's on the back !!!!!!
makka
PostPosted: Mon May 30, 2005 9:45 pm
Discs are made from cast iron. Some have a reputation for warping. Ford had this problem with the AU falcon.
Some are better made than others too- I once bought a Fiat one that had 2mm runout...! I took it back.
The best discs are left a while between casting and machining. This lets cooling stresses in the casting dissipate, less chance of warping after some heat & cool cycles..
I've had good results with Karcraft's S discs (from UK), also RDA and DBA ones. :wink:
Last edited by drmini in aust on Mon May 30, 2005 9:46 pm, edited 1 time in total.
PostPosted: Mon May 30, 2005 9:46 pm
its a squeak on rotation.
PostPosted: Mon May 30, 2005 9:48 pm
Check the disc runout- usually this can be reduced (and the squeak fixed) by repositioning the drive flange on the CV.
 Post subject: Mice?
PostPosted: Mon May 30, 2005 11:09 pm
You may have rodents in your front end....
Hmmm.....maybe you just glazed a pad being a little over exuberant....
PostPosted: Tue May 31, 2005 12:25 am
would your discs and something called "self adjusting calipers" have something in common? or not?
Inconspicuously Conspicuous
PostPosted: Tue May 31, 2005 10:53 am
squeaks are usually caused by microvibrations between the piston and the pad, caused by brake dust getting inbetween them, they sell anti-squeak paste and other things for this reason. Minis are supposed to have anti-squeal plates in there, but most don't have them. I've seen a bit of silastic used to stick the pads to the pistons
could also be glazing as Mick has said
take the pads out, give them a clean back and front, wipe the piston faces down with a clean rag and see what it's like
warped disks would cause violent shudder under braking. They can warp or crack if you do a lot of heavy braking, and then stop without them cooling down under rotation
Users browsing this forum: Bing [Bot], fuzzy-hair-man and 81 guests
