It is currently Fri Jul 18, 2025 11:57 pm
 Post subject: water pump
PostPosted: Fri Aug 26, 2016 7:40 pm
water pump,
when fitted can you still shift the impellor by hand,
or can it only move by pulley and fan belt with fan fitted to harmonic balancer
 Post subject: Re: water pump
PostPosted: Fri Aug 26, 2016 7:47 pm
It should spin easily by hand without the pulley or fan.
PostPosted: Fri Aug 26, 2016 7:57 pm
any causes for not spinning.
PostPosted: Fri Aug 26, 2016 8:10 pm
Siezed bearing, engine sitting for long time and coolant has solidified and locked it up, or plastic fan has deformed and is rubbing on timing chain breather - I've seen all of those before.
Those would be more normal - not sure if say fitting a 1275 pump to an 850 would lock it though.
Whats yours doing? new or old and is it tight or locked completely?
PostPosted: Fri Aug 26, 2016 8:14 pm
when i fitted mine i was advised to check if it spun after install as you sometimes have to get a file out to enable it to spin freely
lucky for me mine just worked i have a 1275
1968 Morris Mini Cooper S
PostPosted: Fri Aug 26, 2016 8:20 pm
I can not spin it by hand, I just bought the engine from someone who said it has a brand new water pump installed.
There is coolant in it from previous owner, I have just fitted a heater blanking plate, can see coolant in it
no fan fitted, just the pulley, and it is not moving.
PostPosted: Fri Aug 26, 2016 8:57 pm
can you store the engine without coolant to stop this happening again?
just ordered a new pump.
PostPosted: Fri Aug 26, 2016 9:40 pm
this ^^
take the pump off, it'll start moving as loosen the bolts
PostPosted: Sat Aug 27, 2016 3:27 pm
you probably have the large impellor type water pump fitted
often they need a couple of gaskets behind, or grind out the offending section of the water jacket/wall behind the pump where it clashes with the impellor
typical situation of someone "thinking" they`re fitting a better pump but not recognising the need to make sure the impellor clears the number one bore/wall/jacket
easy fix tho & better off with the large impellor pump anyways
PostPosted: Sat Aug 27, 2016 4:46 pm
the bolts are to long through the pulley touching the pump even with the fan on
PostPosted: Sat Aug 27, 2016 5:16 pm
If the bolts are too long fit shorter ones!
PostPosted: Sun Aug 28, 2016 5:50 pm
hacksaws work really well too...
PostPosted: Mon Aug 29, 2016 9:39 pm
Should the fan have a spacer too explaining why the bolts are too long?
"Let us remove your "SHORTS"
