It is currently Sat Jul 19, 2025 12:53 pm
 Post subject: Speedo cable lubrication
PostPosted: Wed Jun 01, 2005 9:55 pm
I have a new speedo cable. Are you supposed to lubricate it?
I took the inner cable out and greased it up....hope this was the right thing to do..... :?
PostPosted: Wed Jun 01, 2005 10:00 pm
I beleive one end should not be greased...Unsure length or which end sorry :?
PostPosted: Wed Jun 01, 2005 10:01 pm
Yep, just don't get any grease near the end that goes into the speedo 8)
PostPosted: Wed Jun 01, 2005 10:46 pm
So can he degrease it :idea:
PostPosted: Wed Jun 01, 2005 11:24 pm
As said leave the top 6" bare. A little bit of grease will find its way up there soon enough...
I think it's criminal that you buy a NEW speedo cable, complete, and there's not a skerrick of lube inside it.... :evil:
One I got once was rusty too! I wondered why it was squeaking a week after fitment.. :lol:
PostPosted: Thu Jun 02, 2005 6:37 am
I'd use a dry lube spray, like locksmiths use in expensive locks. Its not graphite, but comes in a compressed can like wd40. Shake and spray and once the highly (and I mean highly) flamable propelant evaporates in a few secs, a clear, clean thin protective film is left over the surface. Even if it gets into the gauge, its light and almoust invisible.
PostPosted: Thu Jun 02, 2005 7:29 am
Grease lube is normal. It's just that now the suppliers don't bother... :evil:
PostPosted: Thu Jun 02, 2005 8:16 am
Sounds like a Silicone spray or possibly Lanolin.
PostPosted: Thu Jun 02, 2005 9:39 am
I have some (ex Qantas) chain lube in a pressure pack can. Maybe that will do the trick.
PostPosted: Thu Jun 02, 2005 10:01 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
that chain lube is sticky
makka
PostPosted: Thu Jun 02, 2005 10:19 am
ok. thanx. What about graphite spray?
PostPosted: Thu Jun 02, 2005 10:31 am
Nope and nope, its called "Siper Lube, dri film" and says it has "syncolon" - thats right I said Syncolon, and no its not just silicone spelt with a Vietnamese accent.
