It is currently Mon Jul 28, 2025 12:55 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sun Jun 05, 2005 10:06 pm
IwannaMini wrote:
Is it possible (if there are no leaks) for the fluid to be "compressed". If fluid is not leaking, how does it ultimately need "topping up"
I am a hydro newbie.....and I ask the same question as you, Mr Photoshop :lol:
PostPosted: Sun Jun 05, 2005 10:32 pm
Fluid does not compress- but we are not talking about steel hydraulic cylinders here.
Top part of a hydro bag is a tapered rubber cone, hence is flexible and can deflect.
Think rubber cone suspension (similar to dry type) with a fluid cavity & valves inside, that is what a hydro displacer is.
:idea: Watch the hydro hoses move up when you bounce the front of the car car down, as the rubber flexes. :wink:
PostPosted: Sun Jun 05, 2005 10:35 pm
Mick wrote:
so are these helper springs able to be re tensioned (is that the right description?)?
Or is it a case of buying new ones if they are available?
Mick
No they are not adjustable, but you could either get some (shorter) ones made, or scrounge some that are not stretched. Kazjim had a pile a while back.
Iwannamini, if it's low, yes I still have ze pompe.. :wink:
PostPosted: Mon Jun 06, 2005 7:38 pm
Mick wrote:
So why do hydro minis seem to sag at the front so bad?
Can this be adjusted out without discharging the system to shim?
I can see three problems that can cause the front to be lower than the back.
1) Look at the design of the system and you will notice that if the car is lowered the rear springs are under less tension. As you pump the car up the helper springs gain more tension. Pump the suspension to the proper pressure and the front will be at the same height as the rear.
2) Hydro bags can sag with age. Swap the fronts and rears around and it can fix the problem.
3) The helper springs lose tension.
PostPosted: Mon Jun 06, 2005 7:44 pm
Helper springs are colour coded. Some time around 1970? they changed the rear strut design, and shortened the helper springs. I think the late ones are all coded orange.. :roll:
PostPosted: Tue Jun 07, 2005 12:12 am
Wire Tie are hand for many thing's but could you Wire Tie off a Couple of Rings :idea: While they are compressed
PostPosted: Tue Jun 07, 2005 7:14 am
Too much pressure for that Gaf.... :lol:
Spring makers still exist in Sydney, could go get some shorter ones made if that is the problem.
I'd find a pair of orange ones that are still good. Everybody and his dog must have some, going by the number of Deluxes & Ks that have been bastardised to dry suspension... :lol:
PostPosted: Tue Jun 07, 2005 8:35 am
Tony from minisport has heaps second hand, sold me a pair for $10 each a couple of weeks ago.
Most places have em, it's just making sure they choose the right ones for you :wink:
matt
PostPosted: Tue Jun 07, 2005 8:33 pm
Woo hoo, I'll give the springs a go.
I don't like the idea of draining the hydro system though....Some evil plans are forming in my mind to avoid this untidy draining business :twisted:
PostPosted: Tue Jun 07, 2005 8:48 pm
Benefits of draining the fluid:
1. It will clean your driveway
2. It'll get the 35 year old rusty water out of the system
3. It'll make it easy to change the springs! :P
You don't need to let it all out, just let down until it's sitting on the bumpstops.
And there's no need to evacuate it before repumping, unless you took the plumbing apart.
Anyhow, I have pump, will travel. PM me if you need it! :lol:
PostPosted: Tue Jun 07, 2005 9:01 pm
Yes that would be handy come time, thanks for the offer!
Does take all the adventure out of it though...
I'm getting too old anyway for busted bones :wink:
PostPosted: Tue Jun 07, 2005 10:32 pm
:lol: Wire Ties are out $10 for new old stock :shock:
What was the originel Length of Hydro Springs
Jim Hunt Lengthened my Spring on the Alfa by 1 1/2" for $100 :idea:
PostPosted: Wed Jun 08, 2005 10:21 am
is it possible for the bags to go POP i just got a delux shell with hydro and a little worried of this happening and thinking of changing to dry also if used on the track is dry way better the wet for handling
PostPosted: Wed Jun 08, 2005 12:00 pm
ihave heared of this as well. i heared that the bags stretch as the hydro
gets old. then people fill them up to compensate for
the stretch and then it goes pop!! but i dont know really its just
something i heared?!?!?
PostPosted: Wed Jun 08, 2005 5:22 pm
These bumpstops might help to releave the pressure on the hydrolastic system a little.
http://www.minispares.com/Product.aspx?pid=33862
There's also a set available for the rear.They've been available for many many years, and will allow you I believe to still get home if you bust a bag although they're really meant to simply stiffen the girl up.
I've got an ancient set on mine at the moment.Image
