It is currently Mon Aug 04, 2025 3:18 am
Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Jun 17, 2004 8:24 pm
ausminis4u wrote:
Bobtel is now running a Nissan Pulsar one. Says hardly any mods to make it fit.. :P
yeh im not a fan of the pulsar dizzys, they are 2 bulky, plus the honda dizzy's curve is very close to that of the cooper 'S' :D it also looks like a lucas dizzy , unlike the pulsar 1 :roll:
I do own an S dizzy, but don't use it- its advance curve is a POS for a well modified motor, IMO. You want advance all over with by 4500, tops. IMO... 8)
PostPosted: Thu Jun 17, 2004 9:04 pm
The pulsar dizzy, (hitachi) is less bulky than the original Lucas. The advantage that it has over the Honda dizzy is that all the workings are internal. There is no seperate igniter box etc.
The advance curve is similar to the cooper s as well. You do not have to shorten the body, cut the shaft etc. Just a quick cut with a hacsaw, a bit of filing, or grinding where the original mount was, and change the drive dog. It really is that easy. Takes about 30 minutes.
the big plus is it only cost me $40 from pick and payless. That was for the dizzy, cap, rotor, coil and leads. Can't go past that. For more info see Marcel Chichaks' TDC web site.
http://www.planet.eon.net/~chichm/
Look in the Tech section. It gives a step by step report on modification, and the dizzy serial numbers you need.
There are thousands of them at the wreckers. And they work. Have done two conversions already.
Bob
PostPosted: Thu Jun 17, 2004 9:08 pm
mate , all 3 of my honda 1s were free :D ( thanx josh ) dunno if they work yet, but im wiring em up on the weekend at the auto electricians :D
lookin for another clubby
PostPosted: Thu Jun 17, 2004 9:18 pm
Bob
Bob, This mod is for the Canadian dizzies, and as far as I know, the Aussie dizzies curve is too aggresive for the A series motors, even though the numbers are the same as the Canadian dizzies. (something to do with the different fuels)
I may be wrong....., but this information was from a fairly reliable source 8)
Are you getting them recurved :?:
Craig
You can take the boy out of the racer.........but not the racer out of the boy!
PostPosted: Thu Jun 17, 2004 10:10 pm
Bob
Craig
Hmm interesting.........if someone could confirm this id like to know.....might have to give a pulsar dizzy a try otherwise
[Maverick] 1971 Mini K
PostPosted: Sun Jun 20, 2004 8:41 am
The dizzy serial number I usde was the D4R85. It stands to reason that being an Australian version it should not be set up to the Canadian emission specs. The serial numbers in Marcels web site can't be found in an Australian wreckers.
I checked the curve with a timing light and dwell tach, an although not exactly spot on it is very close. When I have the time I will get it on a dizzy scope and tune it right in, but for now it works like a dream.
Bob
PostPosted: Sun Jun 20, 2004 10:37 pm
Excellent....i might take a trip to Pick N Payless during the week and rip the dizzy out of a pulsar :lol:
Would it suit a well modified 1275............that was the question i wnated to ask!
PostPosted: Mon Jun 21, 2004 12:29 pm
no worries mate, good luck with it, ill talk to u on msn :D
PostPosted: Mon Jun 21, 2004 12:58 pm
I've been running one of the Pulsar dizzys in my van for over two years! It's been 100% reliable and NEVER cuts out from wet ignition, no matter how hard I try!
A lot cheaper than a Petronix kit, and if the module dies you can get another one easily.
Just did another one for the Moke as well. 8)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sat Jul 10, 2004 8:41 pm
I just did the first of 4 Pulsar dizzys we got last weekend. I can't believe how simple this mod is! Even the shaft hole for the Mini drive dog is in the right place, just needs drilling out for the Mini pin....
The body is the right size, and length, just needs a little filing to fit in the Mini's dizzy clamp.
Gotta get some more Mini drive dogs off kazjim tomorrow so I can do the others... :lol:
PostPosted: Sat Jul 10, 2004 8:55 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i got a few dogs :)
makka
PostPosted: Sat Jul 10, 2004 9:33 pm
Thanx Makka, but I'm going up to see J tomorrow anyway. Swapping some of my Mini crap for his.. :wink:
PostPosted: Sun Jul 11, 2004 1:03 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
you sure they are shitting all over the yard
makka
PostPosted: Sun Jul 11, 2004 9:40 am
D4R85 is N12 Pulsar Manual
D4R83 is N12 Auto.
Casing, dizzy cap etc are identical.
I wonder how different the dizzy curves are?
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Sun Jul 11, 2004 7:17 pm
Got some more Mini drive dogs off J now.. so I'll do the other 3!
Bnicho, what is different on the A+ (I haven't pulled its dizzy out yet) is it much different to fit one to?
