It is currently Tue Jun 24, 2025 3:58 am
 Post subject: Mini k badge/sticker
PostPosted: Sat Dec 07, 2019 1:40 pm
Hi there experts
Does anyone out there know the exact location of the mini k sticker located on the left and right
Front guards?
Thanks in advance
 Post subject: Re: Mini k badge/sticker
PostPosted: Sun Dec 08, 2019 12:17 pm
Pretty much the middle of the A panel... but I'll bet someone has the exact measurements :)
Cheers, Ian
PostPosted: Mon Dec 09, 2019 8:21 am
Someone once posted here that the stickers were dealer fitted and therefore at the discretion of the "fitter". But I would guess there would have been some instructions about location for uniformity.
As Ian said. Mine are in the middle of an imaginary horizontal line from where the external side seam meets the wheel arch back to the door frame edge.
PostPosted: Mon Dec 09, 2019 11:46 am
If you Google "Mini K" there's some images you could use as a reference. Such as:
https://commons.wikimedia.org/wiki/File ... Mini_K.jpg
https://www.morrisminorforum.com/regist ... 8833.7861/
PostPosted: Mon Dec 09, 2019 3:23 pm
Here are 2 period photos. One sticker is higher than the other. I would assume that they were to be fitted centrally on the A panel but not to any specific template.
This photo was taken from an unrestored one owner Mini K. Just another one for you to compare to.
PostPosted: Thu Dec 12, 2019 8:29 pm
Thanks all
Confusing as ever!
PostPosted: Fri Dec 13, 2019 7:03 am
And the brochure in the link here doesn’t have any K badges on the sides :D
viewtopic.php?f=51&t=94542
PostPosted: Fri Dec 13, 2019 10:40 am
[/attachment]
or, the demonstrator model, rally mule, dealer demonstrator whatever, has had a whack on the drivers side front and been re-sprayed and re-stickered...
PostPosted: Wed Dec 18, 2019 9:06 am
Found another period photo of the Mini K A panel badge
PostPosted: Wed Dec 18, 2019 2:37 pm
I would say there is probably a “correct” location indicated by an engineering drawing. However, my Dad worked there as a design engineer and by far the biggest frustration was that assembly instructions were often not followed at the factory floor. If they struggled with correct assembly of important parts of the car I can’t see them ever being consistent with a sticker!!
Interesting about dealers fitting. That’s possible. Cars often left the factory with things like wipers and hubcaps not fitted and same as today the dealer would be doing some prep work such as maybe fitting carpets, removing protective plastic from seats and bumpers, polishing etc. so it’s quite possible they left the stickers for the dealer.
PostPosted: Fri Dec 20, 2019 11:05 pm
It seems it’s half way between the upper and lower door hinge
PostPosted: Sun Dec 29, 2019 7:25 am
Another image of a car for sale.
PostPosted: Sun Dec 29, 2019 10:00 am
Thanks Winabbey
After looking at many it seems your photo is the correct position for the sticker.
