It is currently Mon Jun 23, 2025 11:29 pm
PostPosted: Thu Dec 19, 2019 8:48 pm
There are 2 types of adjustable tie bars for sale ,which is the best type ,also the shock absorbers for the front, KYB does it come with a kit or do you just fit them to existing components .I am fitting comp bump stops to the rear suspension I have to choose well as this is my chrissie present from she who must be obeyed,
Allen Thanks
PostPosted: Thu Dec 19, 2019 9:14 pm
Re the shocky upgrade
I just grabbed some old shocky mounts from another car. The 8 holes are already there in the body. You will need to dig all the crap out of the holes and run a tap down them. I think they are 1/4" UNF. The holes come out the other side in the engine bay near the hydro hose. The top arm needs to be drilled out a bit more as well to take a larger pin for the lower mounting.
PostPosted: Thu Dec 19, 2019 9:35 pm
I also found that the rear competition bump stop hit on the body seam. I had to put a slight flare in the seam to give the bump stop some clearance.
PostPosted: Fri Dec 20, 2019 7:53 am
I think you’ll find there are more than 2 types.
Based on a (really) bad experience - missed the lamp post by thiiiis much - I would buy the kind that adjusts at the hub end. My old ones were threaded at the subframe end ...and snapped through the thread... :shock:
The same goes for the lower control arm. The later ones I have seen have an offset adjuster section. This means they operate with a degree of shear as well as tension/compression. I have heard of these failing....
Cheers, Ian
PostPosted: Fri Dec 20, 2019 8:29 am
blimey if they snap this would be a disaster when driving at 100 k
PostPosted: Fri Dec 20, 2019 1:06 pm
I've had this type for several years, very tough
https://www.minispares.com/product/Classic/21A1091.aspx
need to drill the top arm, I use an 8mm cap screw and a sleeve inside the damper
PostPosted: Sat Dec 21, 2019 4:51 am
I put a write-up on this mod of mine on the how to forum.
Using an M8x100 socket head capscrew.
No need to drill the arm out.
Because drilling a top arm out on the car is hard work, they are tough steel.
PostPosted: Sat Dec 21, 2019 8:17 pm
thx boys
Allen
PostPosted: Sat Dec 28, 2019 5:18 pm
if I can offer some advice on dampers, the 'standard' type dampers do absolutely nothing when fitted to a hydro car, to feel any difference you need some that are pretty firm or adjustables on a reasonable hard setting
PostPosted: Sun Dec 29, 2019 4:50 am
Re the lower arms, the Minisport ones are much stronger. They use big LH and RH threads instead of a small offset end like minispares do.
