It is currently Fri Aug 22, 2025 4:35 am
PostPosted: Mon Apr 13, 2020 1:24 pm
Hinesy1275 wrote:
I have seen many key codes stamped on the square key(way) but less on the escutcheon.
Sorry to stray from the original question, but does anyone have a sample photo of where the key code is stamped on the key way?
We're working on some handles at the moment and can't locate any codes (and it appears that you need to use the key to separate the handle and escutcheon?).
Thanks,
Evan
PostPosted: Mon Apr 13, 2020 3:05 pm
Thanks,
Evan
Although this photo is of the boot, the key code for the door keyway was stamped in exactly the same location - on the side of the square section of the key(way).
PostPosted: Mon Apr 13, 2020 8:11 pm
Thank you, great photo.
Had a look at our door handles but not there unfortunately. Will have to keep sourcing spare keys to keep trying.
Out of interest I had a look at some spare boot handles and found only one out of about a dozen had the number - can't have been a very common practice!
Thanks,
Evan
PostPosted: Tue Apr 14, 2020 7:04 am
Thanks,
Evan
The other location of course is on the front face of where the key inserts, as this relates to the tumbler, but I think this may have even been an earlier 50's BMC practice...
PostPosted: Wed Apr 15, 2020 6:21 pm
Found a key number on the boot lock.
PostPosted: Wed Jun 17, 2020 9:49 pm
Any one know how to remove this square rod.
PostPosted: Thu Jun 18, 2020 8:40 am
Knock out the pin shown here partially protruding.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
Users browsing this forum: Bing [Bot] and 238 guests
