It is currently Tue Jul 22, 2025 11:03 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon Jun 20, 2005 7:57 am
ps I ran Ha-Ha on MiniClassic's rollers last Friday... :shock:
Power I got was about the same as GR's personal 1400 stroker.
OMGMGMGMGMGMGMGMG what power did you get Kev!??!?
PostPosted: Mon Jun 20, 2005 8:02 am
I won't say. :wink:
This old Vane dyno is a bit of a dynosaur.. no printout, and calibration might be suspect. Good for tuning only.....
But GR says it's equivalent to about 120HP on his engine dyno. 8)
PostPosted: Mon Jun 20, 2005 10:13 am
oh Kev I though twe were going to put RED850 and Ha Ha on at the same time. oh well i will have to go down to this other place in Castle Hill if Gregs does not do a print out etc.
100% Pure A Series Turbo
PostPosted: Mon Jun 20, 2005 10:29 am
I know what he got on the dyno :wink:
So barney must go pretty good now with the twins on eh Kev? It will be very difficult to keep up with you on future runs to pie in the sky :lol:
Lillee - 1969 Morris Mini K
PostPosted: Mon Jun 20, 2005 12:07 pm
Well I dropped in at Greg's on Friday, he and GR coaxed me into running it! :lol:
I agree, let's do Castle Hill again. :P Anybody else....??? Brad??
PostPosted: Mon Jun 20, 2005 1:33 pm
I'll be in for that, I'd like to know what Lillee is doing now before the head goes on :)
PostPosted: Mon Jun 20, 2005 3:11 pm
As discussed, once mine is sorted and run in I will be there.
Better wait until after I get the corolla rockers I guess.
:D
PostPosted: Mon Jun 20, 2005 4:16 pm
It wouldn't be "Ausmini Spec" without corolla rockers :wink:
PostPosted: Mon Jun 20, 2005 4:20 pm
yeah i'll be in it
PostPosted: Mon Jun 20, 2005 4:26 pm
Got the RE282 cam today. It's probably got too much lift for my 1.58 rockers, so if I fit it to Ha-Ha's 1360 motor I might have to swap 'em with Barney's Corollas (1.46)! :P :shock:
Nah- I'll run it like it is- keep this cam for next time!
PostPosted: Mon Jun 20, 2005 4:33 pm
So the lift is too high then Kev? How much lift would you get on 1.46 with the new 282?
PostPosted: Mon Jun 20, 2005 4:43 pm
Do you mean too much lift in that to keep that cam and the 1.58 rockers you would have mill valve reliefs in the top of your pistons :?:
I ask cause I had been meaning to ask about this, that is what sort of lift cam can you use with 1.5 and or the corrolla rockers (assuming the head has not been skimmed dramaticly) or the block decked too much ie a normalish compression ratio
I guess I am asking how careful do you have to be about the valves hitting the pistons and should I normally get away without having to get valve reliefs :?:
Roads need more corners
PostPosted: Mon Jun 20, 2005 5:07 pm
0.481" 8)
PostPosted: Mon Jun 20, 2005 5:09 pm
No they won't hit pistons but could make the springs coil bound. My springs will handle .495" lift max.
what does the number refer to when talking about rockers
im understanding the higher the no. the higher the lift the more amount of gas rates
Inconspicuously Conspicuous
Users browsing this forum: Bing [Bot] and 100 guests
