It is currently Sun Aug 03, 2025 12:31 am
 Post subject: Tuning SU Carbs (twins)
PostPosted: Tue Jul 12, 2005 10:07 am
I am searching for info on tuning SU's.
I just pulled this off the net, and thought others might like to read it.
http://zhome.com/ZCMnL/tech/su.html
Hope it helps. 8)
PostPosted: Tue Jul 12, 2005 1:46 pm
After spending the last few days trying to tune my twins....it does help, cheers.
PostPosted: Tue Jul 12, 2005 1:53 pm
that is very interesting. Saved to my computer for future ref!!
PostPosted: Tue Jul 12, 2005 7:37 pm
Took me a whole 10 mins to tune Barneys 2 recon'd HS4s..
You never forget how!
Now I wonder.. do I have the very best needles for it out of the 800? available now.. :roll: :lol:
PostPosted: Tue Jul 12, 2005 7:58 pm
Cool, ive been meaning to tune mine properly... anyone know where to get some of these tools from?
PostPosted: Tue Jul 12, 2005 8:36 pm
A length of plastic hose to listen with replaces tjhe fancy meter everyone recommends. The special jet spanner for adjusting the jet should be available from Midel. Use the piston lifting method for setting the mixture. You actually should not need a spanner to adjust the jet but they do become difficult to turn sometimes. As Kevin says SU's are dead simple to tune once you have the right needle in them. There is no simpler carby.
Chris
Everything I like is either
PostPosted: Tue Jul 12, 2005 8:42 pm
Yep like Chris I just use a bit of plastic tube to balance them- one end in mouth of carb and the other in my earhole.
Just have to use my `good' ear.. :wink:
You can still buy Colortunes, but I'm not sure who carries them. I just read the plugs... :lol:
PostPosted: Tue Jul 12, 2005 9:07 pm
I say to everyone who has a set or even one SU to tune. Make sure the shafts and bushes are in good condition, iIf not life can get a little difficult. SU's don't like air leaks. If there is more than a minor amount of movement then get them overhauled.
Chris
PostPosted: Wed Jul 13, 2005 12:16 am
Got my Colourtune from Autopro Belconnen - pure luck and made it simpler to tune them up. However now sold the twin SU's on Ebay so will see if it works on the dellorto too.
Pricey at $89 but saved me a lot of agro with the ear method
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Wed Jul 13, 2005 12:21 am
Last time I was at Padstow they had a whole bunch...
