It is currently Mon Jul 28, 2025 7:11 am
 Post subject: Miss Fire!!
PostPosted: Wed Jul 13, 2005 6:07 pm
Hi everyone,
My car is missfiring when i first start it up in the cold, sounds like its only running on three cylinders. But once the car warms up its fine. To me it seems like a problem with one of the spark plugs :?
Any suggestions?
Cheers in advanced
PostPosted: Wed Jul 13, 2005 7:24 pm
Pull out one by one and check by holding lead close to the plug listening for a spark.
PostPosted: Wed Jul 13, 2005 7:53 pm
Check your plug gap.
should be 25 thou.
and check your choke is working
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Thu Jul 14, 2005 9:38 pm
I had the same prob, would run on 2-3 cylinders untill warm, then i found my choke cable a little stuffed, didnt go in fully. shes all good now, use choke only to start car, turn off emediatly after start-up, All 4 cylinders work fine!
68' Morris, 1100,
Willson Automotive
Tasmania's ONLY mini Specialists
(03) 62725056
http://photobucket.com/albums/a323/the_white_one/
PostPosted: Thu Jul 14, 2005 9:42 pm
My quick remedy for morning start misfires is to hold the throttle on until valve bounce is acheived... then back off.
Works fine every morning.
PostPosted: Thu Jul 14, 2005 10:01 pm
:lol: :shock:
68' Morris, 1100,
Willson Automotive
(03) 62725056
PostPosted: Thu Jul 14, 2005 10:19 pm
:D
Please nobody try this.
Ar the poor valves :shock: :)
