It is currently Sun Aug 03, 2025 12:00 pm
Post new topic Reply to topic  [ 202 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14
PostPosted: Fri Jul 15, 2005 3:59 pm
:P 8)
PostPosted: Fri Jul 15, 2005 4:37 pm
PostPosted: Fri Jul 15, 2005 6:36 pm
is there a worst award?
(coz this is the best of the worst!!)
:wink:
My rides-74 fj40
74 clubman hopefully rego'd soon....
and 76 clubbie van!! - Ratschite after what i found what it was covered in when i found her...
http://photobucket.com/albums/b44/minimechanic/?sc=1
PostPosted: Fri Jul 15, 2005 8:44 pm
Well I started with this:
was going to be a resto, but I gave up - the front cut was sold for $100 to apparently become a courtyard ornament and the rest went to the stockpile or the tip...
Next one was a bit better:
Before:
After rebuild getting a coat of white knight alpine green paint:
Image Image
After:
just need the Morris sticker or the 'hot run tested' sticker to finish it off
Geoff
PostPosted: Fri Jul 15, 2005 9:10 pm
Hey Geoff, where does your breather run to now... bottle? I can't see... :lol:
Mine's now into both manifold ports- and it idles sweet. 8)
PostPosted: Fri Jul 15, 2005 9:39 pm
Gday Kev
I've been meaning to get a little K&N style filter for the breather on the tappet cover but at the moment its just breathing into the air - is that likely to be a problem?
the manifold vacuum hose is going into the booster. Do you recommend connecting it to both sides? I've had some conflicting opinions about whether theres a point in doing that...
Geoff
PostPosted: Fri Jul 15, 2005 10:33 pm
I'd just replace the elbow you see on mine with another tee and run it from there. There's no airflow from the servo into the manifold, until you hit the brakes.. then you're off the throttle anyway. :wink:
The `balance tube' (hose) on mine has not affected the performance in any way. Still sings all the way up...
Hooking the PCV up meant changing from 50 idle jets to 55, but it was too lean before anyway.
BTW I had it running into a bottle, but my wife kept complaining about the `engine smells in the car'... no problem now!
Users browsing this forum: Bing [Bot] and 76 guests
