It is currently Wed Aug 13, 2025 4:21 pm
Post new topic Reply to topic  [ 79 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Sat Jul 16, 2005 4:24 pm
J_A_M wrote:
cheers dude...I have been in the garage every night till nearly midnight all week...... :D
(fitted my grille last night). JAM has a face :lol:
You have to do something, not just look and drool. :lol: :lol:
PostPosted: Sat Jul 16, 2005 4:28 pm
Good luck tomorrow. :wink:
PostPosted: Sat Jul 16, 2005 5:39 pm
IT'S OFFICIAL!!! I have just driven JAM for the first time in 3 years!!!
.....and I have to say....
I'M EXCITED!!
I spent all last night doing everything. This morning when the family was all up I turned JAM over....and IT FIRED!! :D
The rumble from the zorst is like a drum.....almost rotary like in sound :P It's a very cammy sound...caused by the RE13 and the LCB :wink:
I bled the brakes and clutch and that first drive was magical! I cannot believe the pick up the RE13 cam gives the motor. It says 998 on the block, but :lol: it's far from it!!
The post mortem has revealed 1 or 2 minor issues, but I am a little miffed about the clutch :? It almost needs 2 pumps to function properly....if I don't give it 2 pumps it won't go into gear AT ALL :x I have bled it at least 5 times....no change. Anyone heard of this before?
PostPosted: Sat Jul 16, 2005 5:47 pm
Hey, congrats on the finished job. I'm sure you'll have fun. :D
Reguarding the clutch, that's what mine did some time ago.
Turns out the cylinder had siezed in a position and only got enough pressure to operate
after a couple of pumps. May have to come apart.
PostPosted: Sat Jul 16, 2005 5:48 pm
Congrats Anton.
Re the clutch, check with the doc what master cylinder you have got. It might be what I was mentioning a few weeks back about needing a 0.75 but having a 0.7, therefore not enough fluid volume and travel to engage properly.
Anyhow, they all have minor issues to tweak.
Enjoy.
KB
PostPosted: Sat Jul 16, 2005 5:52 pm
oh oh....the brakes are bled, but feel shithouse too!....maybe I got those cylinders the wrong way around?!?!?!? :x
They are both brand new, as is the clutch slave cylinder.
PostPosted: Sat Jul 16, 2005 5:57 pm
Fluid maybe?
I doubt you'd have cylinders switched, even then they are the same unit.
May need the doc for that one, since we don't get pics till later.
PostPosted: Sat Jul 16, 2005 6:35 pm
Anton did you run the pipe back to the master cylinderas doogie suggested and i showed you the other day? I think it would be a wise move to try that. You will need to pump lots and lots!
Hope you get it sorted. I am going to go reset my timing again. and hopefully mine will fire tomorrow too! hmmmm, i hope it does.
Aaron
PostPosted: Sat Jul 16, 2005 7:19 pm
yes Aaron.....I bled it via that method....then the usual method...then Doogies method again....etc.....etc....
I am sure that when I took the cylinders out of the packaging I matched the part number to the description on the receipt....ie: Part# ??? - Clutch master Cylinder....
PostPosted: Sat Jul 16, 2005 7:21 pm
Congrats Anton! Image How exciting for you! Hope you get the minor probs sorted ready for rego!
PostPosted: Sat Jul 16, 2005 7:33 pm
thanx mum, er.....i mean Trae :lol:
PostPosted: Sat Jul 16, 2005 7:36 pm
why did u call your mini JAM? :? because it looks like jam? :) or just a random name :P
PostPosted: Sat Jul 16, 2005 7:38 pm
Check out his website.
If you don't get it before you even click on the pic in his sig, then you need some help. :lol: :lol:
PostPosted: Sat Jul 16, 2005 7:45 pm
hey Poeee.....I recall you were contemplating building a 1098 with RE13 cam and decent head/carb setup yea?
DO IT!! I am very impressed so far. A 1275 it aint, but it's the next best thing! :wink: :P
PostPosted: Sat Jul 16, 2005 7:47 pm
Sounds good. 8)
Users browsing this forum: No registered users and 255 guests
