It is currently Tue Jul 22, 2025 9:07 am
 Post subject: Van Weights
PostPosted: Wed Jul 27, 2005 9:29 am
Just trying to find out how much difference there is between the weight of the van and saloon. I know the deluxe is listed as 630kg, there can't be too much difference but I can't find it listed in my books. :oops:
Anyone have an idea?
Dan
Margaret - 88 Rover
PostPosted: Wed Jul 27, 2005 9:47 am
I think that the weight of a van is about 615kg but I am unsure doc would know and most other people with vans might be able to tell you but I am preety sure it is 615kg
Pat
_______________________________________________
Team MADMAN/Pat Rogers
From the Haynes manual
Weights
Kerb weight:
Saloon (rubber cone suspension):
Manual transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 638 kg
Automatic transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 658 kg
Saloon (Hydrolastic suspension):
Manual transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 679.5 kg
Automatic transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 699.3 kg
Estate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 686.7 kg
Van . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 621.5 kg
Pick-up . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 622.4 kg
Maximum towing weights:
Saloon . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 404 kg
Estate, Van and Pick-up . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 303 kg
Maximum towing hitch load . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 45 kg
Maximum roof rack load . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 40 kg
Cheers Dat
PostPosted: Wed Jul 27, 2005 11:18 am
Cheers guys.
Bit of a trip that the van can tow less than the saloon. :shock:
Margaret - 88 Rover
PostPosted: Wed Jul 27, 2005 11:22 am
I think that they would be making allowances for all the extra weight the Van could be carrying in its cargo area compared to a sedan boot - [only a guess]
PostPosted: Wed Jul 27, 2005 11:43 am
You're probably right whodat.
Were the vans hydro or rubber cone?
Margaret - 88 Rover
PostPosted: Wed Jul 27, 2005 12:38 pm
All vans/utes/estates were dry suspended (from the factory anyway!)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Wed Jul 27, 2005 12:40 pm
I believe Van's were rubber cone..
They're also heavier than sedan's..don't believe haynes ;)
See here:
http://www.ausmini.com/forums/viewtopic.php?t=7497&postdays=0&postorder=asc&highlight=van+weight&start=0
PostPosted: Wed Jul 27, 2005 1:52 pm
According to my original owners manual (Mk1 '67 model Van)
Van = 1390 lbs = 630.4933943 kilograms.
Cooper S = 1411 lbs = 640.01883407 kilograms
Moke = 1255 lbs = 569.25842435 kilograms
De Luxe = 1435 lbs = 650.90505095 kilograms
I actually have a (registered+accurate) weigh bridge at home, maybe I should use it...
PostPosted: Wed Jul 27, 2005 2:00 pm
Yea, weight them, would be good to know...
PostPosted: Wed Jul 27, 2005 2:06 pm
and from the Manual that I downloaded from somewhere on this forum ;)
Dimensions
Overall length:
Saloon . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3054 mm
Clubman Saloon . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3165 mm
Cooper (1990-on) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3061 mm
Estate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3403 mm
Van . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3298 mm
Pick-up . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3314 mm
Overall width:
All models except Cooper (1990-on) . . . . . . . . . . . . . . . . . . . . . . . . . 1410 mm
Cooper (1990-on) including mirrors . . . . . . . . . . . . . . . . . . . . . . . . . . 1560 mm
Overall height:
Saloon:
Pre-1985 models . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1346 mm
1985 models-on . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1353 mm
Cooper (1990-on) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1331 mm
Estate, Van and Pick-up . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1359 mm
Wheelbase:
Saloon . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2036 mm
Estate, Van and Pick-up . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2134 mm
Weights
Kerb weight:
edit: same as Whodats figures, prolly same Manual, but dimensions for anyone whos interested
www.crazybitchracing.com
PostPosted: Wed Jul 27, 2005 4:27 pm
My van was 660kg on the weighbridge in 2000, but that was with added weight of a wood dash, extra gauges, carpet etc etc. :)
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Wed Jul 27, 2005 6:31 pm
A bit out of topic but the Van weight is very comparable to my 1200 ute at 670kg
PostPosted: Wed Jul 27, 2005 6:38 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
40 kg on the roof huh
i know a guy who used to carry h and i beams on the roof of his mini
bob also knows him
that'll do young fella
makka
PostPosted: Wed Jul 27, 2005 8:36 pm
Minimum me weight. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 75 kg [at the time LOL]
I used to regularly sit on the roof rack while out spotlighting :lol:
