Goto supercheap and buy some u brackets in the trailer section. cut on side of it off and drill a secound hole ig enough to fit onto the front center head stud. other end gets attached to a u bolt and then to whatever your lifting it with. It isn't as nice as other lifting brackets but it is what i use and never had an issue.
In regards to what to fit. do the whole unit with all the bits and peices including radiator etc. you have heaps of room in a clubman engine bay. Tighter in a round nose and even worse in a moke...
Starting it on the floor is easy, and i was taught by doogie as to how to do it. Motor needs 2 things to start. power and fuel.
fuel, get a funnel and attach some fuel hose to it, with the other end feeding the carb. Pour in petrol. you will need to have the funnel on a stand higher that the motor.
power. atttach the positive side of a the coil to a car battery. then with jumper leads, attch the negetive to the earth strap. use the positve jumper lead to wind the starter motor. engine will fire as per normal.
Remember to do this you will need to have the heater hoses connected to each other. otherwise you will get wet. Also make sure you have primed the oil pump. and before starting wind it over to make sure you have oil pressure. Other wise your motor will not last long.
Good luck
Aaron
