It is currently Sun Aug 10, 2025 2:33 am
PostPosted: Mon Aug 15, 2005 7:37 pm
i know this was on here a couple days ago, someone was asking about all the white stuff inside oil filler cap. but i can't find it.
i hve the white stuff, i know this means the engione isn't breathing properly. so how can i fix this? just fit one of those little breather things that looks like a tiny little air filter??? how much are they?
78 Leyland Mini - Prince
PostPosted: Mon Aug 15, 2005 7:50 pm
About $10 from Autobarn. 8)
PostPosted: Mon Aug 15, 2005 7:53 pm
Don't fit the little filter thing. It will not fix the problem.
Do you do a lot of short trips?
Do you have a working thermostat?
Do you have a working PCV system?
PostPosted: Mon Aug 15, 2005 10:11 pm
i do lots of short trips and a few long ones (short trips = up to the shops, also to work, work takes about 20 mins and mmost of that is 100kms
long trips = home to ballarat or melbourne, mostly at 100kms, about an hour for both give or take.
thermostat is great, and PCV??? is that the little breather pipe that comes off the top of the rocker cover? there is no pipe stuck on the end of it
PostPosted: Mon Aug 15, 2005 10:28 pm
Some A series are worse for this malady than others. Stock 1098 had bad ventilation, all 1275s with PCV valve were much better. Late 998 Clubby with sucker pipe on carb was good too.
I agree those poncey little aftermarket filters look nice, but they do SFA except oil up and then block. :cry:
PostPosted: Mon Aug 15, 2005 10:30 pm
Agreed. My Mini K Van does the same as Dylans, but my 1275 LS is fine. I do the same trips in both. 8)
PostPosted: Mon Aug 15, 2005 10:35 pm
I have a 1098, I added a 998 Clubby sideplate breather canister, and ran it to a late HS4 carb with the sucker pipe... :wink:
No mayo problem, last time it was on the road. :lol:
PostPosted: Mon Aug 15, 2005 10:42 pm
so what are you saying? i should connect a little hose from that little pipe on the rocker cover to something?
its a late 998 and i dont have the canister
PostPosted: Mon Aug 15, 2005 10:50 pm
My 1152 has NO breather's apart from the hole in the top of the rocker cover...yes..bad, but i have never had ANY mayo??
Dylan, you could also get a breather that goes from the plate at the back of the motor where the cam follower's are..forget the name :oops:
PostPosted: Mon Aug 15, 2005 10:53 pm
Josh, any trip your car does starts with a good thrashing up/down the M5... :lol:
PostPosted: Mon Aug 15, 2005 11:25 pm
Haha...yes..mostly true...I DO use it to go up to the shops....but then I get carried away having so much fun and drive it further :lol:...it IS meant to be driven isn't it? :roll: :wink:
PostPosted: Tue Aug 16, 2005 6:08 pm
The PCV system sucks the fumes from the engine into the manifold.
Fresh air is allowed into the engine to replace the bad air!
On the 1100 the hose from the top of the rocker cover is supposed to go to an adaptor between the carby and the manifold. It should also have a side cover with the "flattened pipe" The end of the pipe is not blocked but has a very small slot and it must be clean.
PostPosted: Tue Aug 16, 2005 7:24 pm
Engines with a PCV had a filler cap with filter in it.. sort of.
PostPosted: Tue Aug 16, 2005 11:36 pm
I've blocked up both rocker cover breather and have no crank case breather. I replaced the side tappet cover "flat pipe" with a cooper S type oil separater breather and run that into a PCV and into the dellorto intake manifold. No Mayo, and I do a lot of short trips...
PostPosted: Wed Aug 17, 2005 6:45 am
The so-called breather cap used on Cooper S, Morris 1100S etc didn't let much air in anyhow... if you took it off while running it affected the idle a fair bit.
I'm running a sealed cap on Barney with the flywheel housing breather going to both suction ports on the twin HS4s. No mayo either. :wink:
Users browsing this forum: Bing [Bot] and 88 guests
