It is currently Sun Aug 10, 2025 4:46 am
 Post subject: 1100s v cooper s blocks
PostPosted: Tue Aug 16, 2005 8:54 pm
Is there a difference in Oil and Water galleries in these two blocks? And hence making the heads not swappable?
Aaron
PostPosted: Tue Aug 16, 2005 8:58 pm
1100S and Cooper S will interchange. No differences really.
But a Morris 1100 is a different animal. :wink:
1275 head gasket fits all 1275s...
Last edited by drmini in aust on Tue Aug 16, 2005 8:59 pm, edited 1 time in total.
PostPosted: Tue Aug 16, 2005 8:59 pm
Nope no difference, my MUM has a solid block Cooper S engine in her car, still blows head gaskets and cracks it once a year
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Tue Aug 16, 2005 9:01 pm
Heads are swappable aren't they :?: AFAIK
Cooper S heads have one more head stud or bolt(can't remember) but the 12G940 can be modded to have this as well,
1100S doesn't have the tappet covers on the back of the motor and gets less bore flex apparently due to have extra webs....
Roads need more corners
PostPosted: Tue Aug 16, 2005 9:04 pm
"my MUM has a solid block Cooper S engine in her car"
Hmm solid block Cooper 'S' engine??? Nah
PostPosted: Tue Aug 16, 2005 9:05 pm
Interesting, i was just looking at the two blocks and the rear center water jacket hole on the s block is a small hole, similar to a oil hole. Where as the center hole on the 1100s block is a bg hole(same as the other two water holes) Thats why i asked as i thought, maybe the center hole on the two blocks were actually different. Oh well worth asking i guess.
Aaron
PostPosted: Tue Aug 16, 2005 9:12 pm
Yes, solid block S engine... 1968 Pommie import
factory 11 stud, high compression.
twin su's, extractors.
4 synchro, close ratio.... oh and rubber uni's
PostPosted: Tue Aug 16, 2005 9:42 pm
1275 heads are all interchangeable.. number of head studs excepted. I've got a MK2 S motor with a worked 1275 LS (12G1316) head on it. It's got the 2 extra stud holes now, too... :wink:
PostPosted: Tue Aug 16, 2005 10:08 pm
i was thinking similar Aaron....I had this type of issue in my SLR 5000 years ago. I put an old 308 intake manifold on a newer 308.....water / oil jackets didn't match......got a milky surprise :shock:
PostPosted: Tue Aug 16, 2005 10:11 pm
Um Aaron... are the brass drilled core plugs at each end still there, and flush with head face? Near #1 and #4 exhaust valves.... gasket overlaps them... if they move you can get milky oil or oily milk! :cry:
PostPosted: Wed Aug 17, 2005 10:39 am
Good call Doc, but they look Solid :cry: I will try another head tonight or the next night.... See how we go.
Aaron
PostPosted: Wed Aug 17, 2005 9:30 pm
Still as I said "Nah", accordinding to the books. Maybe a Morris/Austin 1275/1300 GT saloon engine.......
Very clear to anyone when you said rubber drive shaft couplings. They were only on the very very early 1275 'S's in the UK 1965-1666 (OK for 1071 but the torque of the 1275 was a problem) .
I could go on but enough...
PostPosted: Wed Aug 17, 2005 10:21 pm
Keep Guessing....
getting warmer though
PostPosted: Wed Aug 17, 2005 10:27 pm
MG 1100/1300 :roll: :D
PostPosted: Wed Aug 17, 2005 10:32 pm
Good one willy.
Users browsing this forum: No registered users and 111 guests
