It is currently Sat Jul 19, 2025 12:12 am
PostPosted: Mon Aug 22, 2005 10:16 pm
Guys, I've sorta reconditioned a rocker shaft (strip, degrease and clean, rebuild) for my temporary engine, but was needing to know how to adjust the rockers. I have the black book (workshop manual), but not sure what I need to do. Could someone give me a step by step on how ot do this please. I've got the engine running, but its a bit hotter than before and not as smooth, so I was hoping to get these dialed in.
PostPosted: Mon Aug 22, 2005 10:44 pm
Various ways to adjust them properly, best known (and most accurate) is the "rule of 9"..
Looking at the motor from the front of car, there are 8 rockers across it.
Imagine they are numbered 1 to 8. The rule is when one valve rocker is at full lift ie. valve open, you adjust the corresponding one that always adds up to 9. So if #1 is at full lift adjust #8, if #4 is at full lift adjust #5, etc.
Valve clearance is .012" with stock cams, but if you have a modified cam they are usually run at wider clearance.
Cooper S are usually run at .015" for competition use.
Kent cams use .016", Russell Engineering RE-13 uses .016", both with stock rockers.
I put the car in 4th gear and roll it forwards.
BTW if you retighten the head, you should always check the rocker clearance afterwards. :wink:
PostPosted: Tue Aug 23, 2005 5:51 am
Kev can do this with his eyes shut, one hand tied behind his back and half drunk :wink: Trust me I've seen it done in person more than once :lol:
Lillee - 1969 Morris Mini K
PostPosted: Tue Aug 23, 2005 7:16 am
just to clarify...when rocker number 5 fully open..means the value is fully open..so the rocker has depressed the spring to full travel.
Email sent with scan from mag :wink:
PostPosted: Tue Aug 23, 2005 7:37 am
yep thats right, fully open means the valve is at its highest point of travel before it starts to close again.adjust number 4 if no 5 is open fully.
PostPosted: Tue Aug 23, 2005 8:17 am
Yeah-That's all good.Iistead of rocking the car back&forward,try jacking one front wheel off the floor,and with Mini in 4th gear,turn the the wheel by hand and watch the rockers,and go thru the sequence.Always double check when finished,and check again that you have tighten the lock nuts.
PostPosted: Tue Aug 23, 2005 8:24 am
Thanks guys, big thanks to Jim for the guide.
Will have a go later this week. I really should stop fart arsing about with this engine and get on with the floor replacement :P
PostPosted: Tue Aug 23, 2005 9:01 am
Good tip for working in small garages :wink:
PostPosted: Tue Aug 23, 2005 9:03 am
A little less chance of hitting your head on the bonnet also :oops: I think I did that three times at the Brit day
PostPosted: Tue Aug 23, 2005 12:49 pm
1. is there a specific direction of numbering them: left to right, right to left
2. if you have an automatic you have to tap the ign key
Inconspicuously Conspicuous
PostPosted: Tue Aug 23, 2005 1:07 pm
numbering starts at the rad end (piston #1)
PostPosted: Tue Aug 23, 2005 3:39 pm
I thought you could push start mini automatics, so should be able to turn the motor over by pushing....
but instead of getting out from under the bonnet, put screwdriver across the starter solenoid, or turn the motor with the fan, a bit of pressure on the fan belt with one hand to stop it slipping, and easier with the plugs out of course...
PostPosted: Tue Aug 23, 2005 3:57 pm
You can push start a Minimatic. You push it to 35mph and stick it in low. :wink:
So it will not help when setting tappets. :lol:
PostPosted: Tue Aug 23, 2005 10:50 pm
Taking the plugs out is a great trick also..I notice this last time...just make sure you know where they go back to :shock:
PostPosted: Tue Aug 23, 2005 10:54 pm
When I had the `matic in I used to put a spanner on the alternator pulley nut, press down on top run of fan belt. It'll turn over nicely. :wink:
Don't use the plastic fan blades to turn it, they break!!
Users browsing this forum: No registered users and 69 guests
