It is currently Fri Jul 18, 2025 9:50 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
PostPosted: Fri Sep 02, 2005 10:11 am
I,ve just bought a 68 van and want to pull out the side windows to patch up and paint. Window rubbers are perished beyond reuse.
There is probably a thread on this here somewhere.
The confusion I have is this. :?
Are van windows non-standard ( dealer fitted accesory )?
If so: Where to buy the window rubber?
And what would the part?product be called?
Its a pretty small profile strip by the look of it.
Any help on this appreciated.
I haven't owned a mini since my P plates. Which was long ago.
Getting back into it.
PostPosted: Fri Sep 02, 2005 10:59 am
Welcome. Good question and I don't think we have had this before....well not for ages anyway.
I don't have an answer, sorry. Someone will....
PostPosted: Fri Sep 02, 2005 11:11 am
Do you have a pic? I have a full set of the rubbers from my Clubman van which I don't need. Two on each side. Post a pic and I'll see if they're the same.
PostPosted: Fri Sep 02, 2005 1:20 pm
Check out Jill200sx..she's just done allthat :wink: :wink:
PostPosted: Fri Sep 02, 2005 1:35 pm
Sorry Gaf, I removed the windows and filled them in, I think he wants to replace the rubbers and put the windows back in ;)
Any windscreen place should have them though.
www.crazybitchracing.com
PostPosted: Fri Sep 02, 2005 3:31 pm
Thanks everyone.
angusdog, I'll post a pic for you on saturday, when the boss lets me loose.
Yeah I just want to put the windows back in. Though filling in the panel does sound like an interesting option jill200sx. Is it complicated?
I hope to do my van up gradually. Its pretty tired looking now. But for $1500 I think its ok.
Best feature, rego sticker.
68 mini 1100 van (mine)
68 1330 sedan (Michelle's)
PostPosted: Fri Sep 02, 2005 3:43 pm
You can use the front rubber and locking strip on the sides. the rear windows are different.
Aaron
Fellow Van owner
PostPosted: Fri Sep 02, 2005 4:21 pm
I think all vans unless they are a traveller came out without the rear side windows in them, so all of the vans out there that have windows in the side have been cut into them afterwards.... ( i think)
Life's a garden.... Dig It!
PostPosted: Fri Sep 02, 2005 9:20 pm
Glass companies are always putting windows in vans, so they would have suitable rubber seals. Glass was put in all mini vans after sale.
Chris
Everything I like is either
PostPosted: Fri Sep 02, 2005 11:10 pm
I don't think that's true, as the vans with windows dont have that support thing half way down.
PostPosted: Fri Sep 02, 2005 11:27 pm
Most vans had the windows fitted by the dealer. Often you can tell where the strengthening bar was cut out top and bottom.
Regardless, the rubber was usually an off-the-roll universal type. Clark rubber stock it.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Fri Sep 02, 2005 11:31 pm
You can still see the remnants of my support beam - real botchy job of cutting it out of the way to fit the windows :?
Anyways - any windscreen mob would be able to replace the rubbers or fit for you. The there is always Clarks Rubber if you want to do it all yourself.
Cheers Dat
PostPosted: Sat Sep 03, 2005 6:34 am
Mine still has the support as it has two windows each side, and I think done by the dealer as an option when purchased.
PostPosted: Sat Sep 03, 2005 6:18 pm
while on the discussion of van rubbers... does anyone in Sydney know where I can get the rubbers for the windows in the back doors (the square windows) and for the actual doors themselves (the seals)... MG Spares dont have either of them...
Also how do you "tighten up" the side windows on a traveller..? They rattle too much for my liking.
PostPosted: Sat Sep 03, 2005 8:08 pm
Scots old auto rubber http://www.scottsoldautorubber.com.au/Morris%201959-72%20Mini%20&%201973-78%20Lelyand.htm
It's pretty well the only place other than spectrum(and cheaper inclusive of poastge) to get your rubber needs! :wink:
Aaron
Users browsing this forum: No registered users and 116 guests
