It is currently Thu Aug 14, 2025 7:29 pm
PostPosted: Sat Sep 03, 2005 2:45 pm
I wacked on the 1.5" carbie, now i have run into some issues.
It was running realy really rich (plugs were BLACK and it kept backfiring)
But now i dont know if its running too rich still or if there are other issues.
Its coughs and tries to keep running after I turn it off with the key.
And, it seems be be running fairly hot.
And, if I push that screw thing up with the spring, it idles faster, i thought it was supposed
to nearly stall ?
Please help!!
Do you guys think it is still running waaay to rich ?
No more Minis!......For now.
PostPosted: Sat Sep 03, 2005 3:03 pm
Dieseling is usually a sign of being too rich. Doc but know but!
Noli Illegitimi Carborundum
PostPosted: Sat Sep 03, 2005 5:12 pm
Well, I got it running ok now, well at least when im driving
Idle RPM is a tad higher than like it, about 1100RPM, the old 1 1/4 was about 1000 to
800RPM.
Still having the issue of spluttering after I turn it off though.
Any suggestions ?
PostPosted: Sat Sep 03, 2005 5:49 pm
Did some research.
I think my accelerator cable may be sticking and holding the carbie open slightly.
PostPosted: Sat Sep 03, 2005 6:28 pm
Just took it for a good run.
Increase in power is awesome!!
I can feel it just has more grunt!!
SO DAMN HAPPY!!! :D
PostPosted: Sat Sep 03, 2005 7:18 pm
to nearly stall ?
Please help!!
Those are all signs of running too rich.. it's not nearly supposed to stall when you lift the pin up.. it should pick up in revs slightly and stay there... if it stalls of cuts back in revs it's running too lean.
PostPosted: Sat Sep 03, 2005 8:07 pm
NAV-MAN
I've always believed that if the revs drop straight away it's too lean.
If they rise it's too ritch.
If it rises then falls to about the same then it's pretty close.
This affects the mix over the whole rev range.
Maxi23 are you running a standard exhaust? i.e cast iron or are you running extractors like lcb's?
If its std NAV used to run a ABX needle and went great.
PostPosted: Sat Sep 03, 2005 8:32 pm
I'd look at your timing too, and look at running a set of hotter plugs..
PostPosted: Sat Sep 03, 2005 11:15 pm
Running Extractors.
Plugs look ok, but arent in great condition.
Timing hasnt been looked at since rebuild, so i may check that out also :)
Thanx For the help guys!!!
PostPosted: Sun Sep 04, 2005 11:12 am
"running on", after you turn it off is a sure sign of it idling too high (at least) often it`s also a sign of over advanced ign timing & can also be a sign of engine running too hot,,,any one, or combination of all three, will tend to make them "run on"
easy-peasy
& yeah, it still sounds a bit rich tho :-)
PostPosted: Sun Sep 04, 2005 11:21 am
How do I stop the engine from running hot ? or is this not possible ? It seems to be running hotter with this 1.5" than with the 1 1/4" carbie.
Would it be running hotter if too rich ?
Cooling system is running fine as far as i know.
(Also, it kinda flat spots for a second, then kicks in....if I plant my foot in 2nd and 3rd gear)
PostPosted: Sun Sep 04, 2005 4:22 pm
What if it rises 100 rpm only then dropes and stalls
PostPosted: Sun Sep 04, 2005 6:35 pm
NAV-MAN
What do the plugs say? are they clean, black or brown?
Clean (with maybe some white spots) = Lean
Black and wet = ritch
Brown = Pretty darn close so don't bother changing it.
That reminds me i must chack NAV's plugs. Gap etc.
PostPosted: Sun Sep 04, 2005 6:41 pm
I'll check tomorrow arvo...as I clean them up today and that way it has a good run that way
PostPosted: Sun Sep 04, 2005 6:53 pm
NAV-MAN
If it's running fine leave it.
Users browsing this forum: AWOODY, Bing [Bot] and 235 guests
