It is currently Thu Aug 14, 2025 9:30 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Sep 09, 2005 8:11 am
First thing I would do- pull the clutch lever arm out and check the bottom ball bit is not bent/broken...
Easy fix if so! :D
crap - I have even had this problem before. See - I didn't even think of that. When you've been working on a car till after midnight and stuff doesn't go your way you don't think straight.
Hang on - still not thinking straight. The shaft that holds the thrust bearing was moving fully - this would indicate it being internal wouldn't it??
Bob Slattery
PostPosted: Fri Sep 09, 2005 8:16 am
Online
If it's moving fully, you are right. But these arms often crack and flex a bit before they break off. BTW never attempt to TIG weld one, they are heat treated, it just don't last.
Not much inside I can think of inside that will stop the clutch freeing, unless primary gear is dragging as I said..
PostPosted: Fri Sep 09, 2005 8:30 am
Which Thrust Bearing did you use...the tall one or the short one :idea:
PostPosted: Fri Sep 09, 2005 8:48 am
Special one. from an Austin Kimberley. REALLY STRONG and nearly brand new.
Bob Slattery
PostPosted: Fri Sep 09, 2005 8:51 am
Poor bob : (
good luck mate!!
PostPosted: Fri Sep 09, 2005 9:02 am
MrBob wrote:
No nuts on mine, or 90% of race Minis either! :lol:
If clutch pedal feels fine maybe the primary gear is dragging. Is it OK cold?
Brand new primary gear
Checked end float?
my thought exactly. Maybe it is jammed and can't spin? :?
PostPosted: Fri Sep 09, 2005 9:04 am
Just spoke to Graham and he said he set it up with plenty of endfloat and moly grease on the primary gear. It is unlikely that is has seized. He also suggested that it could be a cracked clutch arm - even though it looks like it's moving fully, it could be cracked - I have an extra heavy duty diaphragm in it so it is a possibility.
I am going to get away from work as soon as possible to check it out.
Bob Slattery
PostPosted: Fri Sep 09, 2005 9:08 am
clutch arm here if you need one. How did you go with the throttle linkages?
Aaron
PostPosted: Fri Sep 09, 2005 9:20 am
Clutch arms are about 30 bananas new. Same with the bearing carrier. FWIW....
PostPosted: Fri Sep 09, 2005 9:32 am
Dam Bob sorry to hear this... I hope you get it fixed this afteroon... Been years since I played around with a clutch on a Mini so Im not much help sorry..
Opinions expressed by me are of my opinion only and are copyrighted to Kinkabell Corporation? 2006.
PostPosted: Fri Sep 09, 2005 9:49 am
Aaron
Thanks man
Linkages came up good - Alan ended up having a similar plate to the one you lent me, and the actual linkage off a marina works for anyone elses future reference.
Brand new throttle and choke cables.
I had to steal your choke cable clamp but will buy you a brand newie when I go to heritage. Should be able to give it all back to you next time I see you, or can bring it around sooner if you want to install it soon 8)
Bob Slattery
PostPosted: Fri Sep 09, 2005 9:52 am
i'm sure you will be there tomorrow mate, i will grab the carb then, it'll give me something to do next week. choke we can work without until you get my parts back to me.
Aaron
PostPosted: Fri Sep 09, 2005 7:54 pm
So did you fix it?
Aaron
PostPosted: Fri Sep 09, 2005 7:57 pm
It's running - but rough.
The HIF44 I got is in crap condition, and it looks like I need a new one.
Makes good power though - but hard to drive.
I'll see you all tomorrow.
Bob Slattery
PostPosted: Fri Sep 09, 2005 8:03 pm
well done mate.
re carb, i would just have it rebuilt. cheaper for sure.
Aaron
Users browsing this forum: 1071 S, drmini in aust and 277 guests
