It is currently Sat Jul 19, 2025 7:02 am
 Post subject: Plugs - BP6ES or BP5ES
PostPosted: Mon Sep 12, 2005 9:58 pm
This question has come about from a a brief comment in another post.
For an A series motor, with unleaded head and running on 98 octane unleaded fuel, are BP6ES plugs OK, or should you use BP5ES plugs?
....and why?
PostPosted: Mon Sep 12, 2005 10:00 pm
You can use either. If you drive it hard the 6s are good, if lotsa traffic stick to 5s.
I use 6s in ha-ha, for wakefield I put 7s in.
Try them...
Cause Graham says so, cause they burn hotter so don't foul up as much, cuase... I think they burn better. I used to have heaps of problems with BP6ES until I changed to BP5ES and never looked back.
Have you checked your plugs? if there's nothing wrong, why bother? save your dosh until something goes wrong I say..
Lillee - 1969 Morris Mini K
PostPosted: Mon Sep 12, 2005 10:40 pm
this may sound stupid but are the BP5ES alright for a fair bit of highway use?
67' Matic
73' S
PostPosted: Mon Sep 12, 2005 11:04 pm
I use 5's ;) ..well W8 Bosch..
Mine are fine for plenty of Hwy use :)
PostPosted: Tue Sep 13, 2005 7:32 am
If you have your carb set up right, then i would use 6es for long hwy use. as most cars lean out toward the top end(i say most, not all) City driving 5es. in the heat of summer you car is gonna run hot enough so i stick with 6es for dec,jan,feb, then switch back to 5es. Works for me
Aaron
PostPosted: Tue Sep 13, 2005 8:43 am
not a bad theory that.....
Users browsing this forum: Bing [Bot] and 78 guests
