It is currently Sat Aug 02, 2025 8:30 pm
 Post subject: Today's test drive
PostPosted: Sat Oct 22, 2005 11:39 am
Okkher ;)
I've got my new (SH) shocks in the back and it's now handling like i expect a mini to handle...
So I took him for a "quick" run this morning and as i went the old boy just got smoother and smoother.. a right royal dusting of the cobwebs Image
so now i'm back, after 3 hours :oops:
something i've noticed as a result of this mornings effort is that on long sweeping (quickish) left hand turns there seems to be a small amount of play in the steering... there's about an inch of turn before anything decent starts to happen and it doesn't seem to have much fedback as a similar right turn does.
and on a heavy left turn, i can hear a creaking from the rear right.. the shocker that i removed from there yesterday was totally cactus.
what's going on mini brains? ;)
edit.. i should've taken my camera too.. it was a nice tour..
lenswood, woodside, oabank, balhannah, littlehampton, naire, mt barker springs, upto the mt barker summit, nairne, littlehampton, mt barker, hahndorf, balhananh, mt barker, then back home via balhannah again :)
on the road into balhannah, something happened that i've been keen to experience since getting the mini...
i found myself with a rather impatient honda crv behind me :twisted: (same model as mine) so i sped up... and he did too...good... i've wanted to compare this for a while.... and it was great... it took about 2 corners and then he backed off :)
PostPosted: Sat Oct 22, 2005 2:16 pm
Looks like you made a fair expedition.
So you're happy with your shockers then :lol:
You got it right in the end, don't worry too much.
8)
 Post subject: Re: Today's test drive
PostPosted: Sat Oct 22, 2005 2:47 pm
Just reading those towns you drove thur,brings back great memories.You have some
fantastic roads over there for the Mini driving experience.
:D :D
PostPosted: Sat Oct 22, 2005 4:21 pm
I know you wanted to compare your two cars......but did u honestly think that a top heavy soft-roader would scare ya in the twisties? He probably scared himself! (and backed off....like you said)
oh, and have you greased your nipples lately? :) (creaking noise)
1962 Morris 850.....with a 1310
1998 Toyota starlet.....161.1hp atw
PostPosted: Sat Oct 22, 2005 5:56 pm
i've sussed the noise....(well ... had it sussed for me)
it's wheels scrubbing against the shocks...
there's about a bees dick width between the tyre and the shock :shock:
it's all good... just gotta learn to balance the car better in cornering.. :)
no where's that tofu?? :roll:
PostPosted: Sat Oct 22, 2005 6:11 pm
have you got wider wheels without spacers?
also sounds like you could use a wheel alignment?
PostPosted: Sat Oct 22, 2005 9:19 pm
that shocker was well and truly frucked :lol:
PostPosted: Sat Oct 22, 2005 10:10 pm
Location: thornleigh sydney...round crnr from suzitech!!!!
id be going for spaced drums if you dont already have them,
blake :wink:
ausmini member 195
71K 'Kaye', KAZZ69's work in progress
66 panelvan, going no where fast...
71 MS75 toyota crown COUPE :) yes A COUPE!
76 ra23 celica wid 1ggte, GT3071r, 13.5@106mph with alot of spinin....
wheels keep on turnin!
PostPosted: Sat Oct 22, 2005 10:22 pm
I don't think Cushy is useing Spaced drums..
Mate you can't let of the go pedle in a corner :cry:
PostPosted: Sun Oct 23, 2005 12:18 am
wonder if he has single leading shoe's given that its an 850 :D
PostPosted: Sun Oct 23, 2005 12:27 am
Yep, and only one's doing its job properly :shock:
Cant be good... I'll have to give him a drive of my LS to taste the disc brakes. Oh, and POWER.
PostPosted: Sun Oct 23, 2005 12:32 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
not the space is between cushy's ears :)
msakka
PostPosted: Sun Oct 23, 2005 8:17 am
it's alright.. i'm getting the hang of not using them at all.. :)
lenswood to balhannah..... 5 uses :twisted:
PostPosted: Sun Oct 23, 2005 8:43 am
i try to tell the disc brake boys that they don't slow you down if you don't use em
PostPosted: Sun Oct 23, 2005 9:00 am
the gearing does it all for you :)
Users browsing this forum: minihahanz1 and 112 guests
