It is currently Sun Jul 27, 2025 10:11 pm
PostPosted: Sat Nov 05, 2005 1:45 pm
I have a replacement head gasket all ready to go on after cleaning the head and block up.
One side is metal, other side is a softish type texture.
Which way faces upwards ?
Other gaskets I have had had text telling which way was supposed to be at the front and left, but this one doesnt have anything on it whatsoever.
Any help is appreciated.
Thanx!
No more Minis!......For now.
PostPosted: Sat Nov 05, 2005 1:56 pm
I just bought a head gasket mine says which way is up though.. Can't help you sorry... have fun replacing it, I cracked the shits trying to drain the radiator and gave up.
PostPosted: Sat Nov 05, 2005 2:10 pm
I just undid all the hoses and let it all go down the drain :)
PostPosted: Sat Nov 05, 2005 2:26 pm
sounds good.. I'l give that a go.
PostPosted: Sat Nov 05, 2005 2:32 pm
alright fk that... i cracked the shits again.. next time I'll throw a brick at the damn thing
PostPosted: Sat Nov 05, 2005 3:37 pm
that's the spirit! :D
Bling me up Scotty!
PostPosted: Sat Nov 05, 2005 4:27 pm
Posted at 2:26pm
h0nk wrote:
alright fk that... i cracked the shits again... next time i'll throw a brick at the damn thing
Posted at 2:32pm
LOL... 6 minutes!
- Simon -
PostPosted: Sat Nov 05, 2005 5:10 pm
Molina wrote:
Posted at 2:26pm
Posted at 2:32pm
LOL... 6 minutes!
hahah yeah I went out unscrewed the hose clips but the hoses were all stuck.. I couldn't manage to pull any of them off.
Maxi23 sorry for stealing the thread. Can anyone help with the gasket problem?
PostPosted: Sat Nov 05, 2005 8:26 pm
I'm pretty sure the correct way is the hard side up.... the gasket is working on the 998 I did a couple of weeks ago, and it's hard side up...
H0nk, try twisting the hoses before pulling, that'll crack the seal, then if they're still hard, gently lever with a screwdriver - GENTLY... ;)
PostPosted: Sat Nov 05, 2005 8:55 pm
hard/copper side is top from all motors ive done b4...is it exact mirror image to rotate and fit upside down??
PostPosted: Sat Nov 05, 2005 9:11 pm
yeah it is a mirror image - it took me ages to decide which way up to put it, in the end I thought back to whether I had to scrape the block or the head clean of the old gasket - it was the block... soft side down
PostPosted: Sat Nov 05, 2005 9:54 pm
all these so called bloody experts and not one has given you the right info.
its like a piece of toast, isnt it?
put jam on the headgasket, throw it in the air , when it lands jam side down , you know that that side should face up.
HUH! AND PEOPLE SAY THAT I HAVE NO MECHANICAL KNOWLEDGE! PHU!
the mokeman cometh...........
PostPosted: Sat Nov 05, 2005 11:16 pm
Have you had a close look? they're usually labelled 'TOP'...
PostPosted: Sun Nov 06, 2005 5:54 am
and `FRONT'... (might be, if was on a Morris Minor..):lol:
With newer composition ones as Con the Fruiterer would say `dus'n matter'- the thing is symmetrical and will seal either way up. I've taken lots off where the PO couldn't read `top' or `front'... :wink:
PostPosted: Sun Nov 06, 2005 6:07 am
surely you cant get the front wrong..you would not be able to get it over the studs :!:
When I used the copper one's on the 1100 it always had top, but then I changed to a differnt (acl) gasket and always found the shinney side was down..but if its mirrored..should not matter, you have it on the correct way up :wink:
Users browsing this forum: fuzzy-hair-man and 82 guests
