It is currently Sat Jul 19, 2025 4:41 pm
 Post subject: holy crap...just get JK
PostPosted: Sun Nov 13, 2005 7:09 pm
http://cgi.ebay.com.au/MINI-4-SPEED-STR ... dZViewItem
no way can that be worth $4000...
Bling me up Scotty!
PostPosted: Sun Nov 13, 2005 7:11 pm
well i think the straight cut drop gears are worth $900 alone
then theres lots of other goodies kad quikshift $200
bla bla bla i dunno
PostPosted: Sun Nov 13, 2005 7:15 pm
each? or for a full set?
Bling me up Scotty!
PostPosted: Sun Nov 13, 2005 7:19 pm
good value
PostPosted: Sun Nov 13, 2005 8:57 pm
well I just had a look at minispares and the straight cut gear kit is 750 pounds and the drop gears about 200 pounds, so there is $2500, add the diff and the quick shift and assembly and a few other bits like bearings and syncros and its probably close to the mark at $4500
PostPosted: Sun Nov 13, 2005 9:35 pm
wake up & smell the roses Andrew,,,
good bits cost good money, simple as that.
remember that when you`re ready to fork out for all the "good gear" you will be needing when time comes
hee hee,,,how`d you like a super dooper Close ratio 6 speed dog box with slippery quaife diff & S/C drops???
want to even have a guess what it costs??????????????????????????
PostPosted: Sun Nov 13, 2005 9:42 pm
Should i sit down first?
I'll bet 8k. :?:
PostPosted: Mon Nov 14, 2005 6:07 am
I'll bet 8k. :?:
And if you bust gears etc in that KG box Matt, who's got any spares.... :?
They went bust didn't they.....!
PostPosted: Mon Nov 14, 2005 7:55 am
the thing was that this gb is $4000ish...you could get a similarly spec'd jack knight box for that...sure you would just get the gears (ie. no gear housing or quickshifter...) but wouldnt a jack knight box brand new be better than a 2nd hand reconditioned box like this?
Bling me up Scotty!
PostPosted: Mon Nov 14, 2005 8:29 am
From what I have seen and heard over the last few years the JK gears are not as good as once was, the case hardening is failing
PostPosted: Mon Nov 14, 2005 8:36 am
hmmm...thats not good news...i thought they just landed some deal with a few F1 teams to make boxes for them...
Bling me up Scotty!
PostPosted: Mon Nov 14, 2005 9:02 am
Would suit Race/ Rally car
hence $4500 :)
i want it!
PostPosted: Mon Nov 14, 2005 9:07 am
Right now, the MiniSpares 4 synchro SCCR gears are probably best for racing- unless you can afford the new sequential dog box KC is raving about.
PostPosted: Mon Nov 14, 2005 9:11 am
Mate, Formula one gearboxes are built to last just the length of the race and then they are thrown away, they build them as light as possible and usually dont have a full box of gears left at the end of the race
Straight cut boxes are not really good for street use as the nature of the box is to be strong and not consume as much power as a helical cut box but the mating surfaces of the gear is actually less than a helical box so there for the gears are not as durable for milage
Jon
PostPosted: Mon Nov 14, 2005 9:35 am
perhaps it is overkill for your needs anyways
the standard mini box isnt that weak as long as your not driving like a maniac 24/7
IF you are building a full blown race car go for it
if not i wouldnt spend it imho
