It is currently Sat Jun 28, 2025 2:41 pm
PostPosted: Tue Nov 15, 2005 10:08 pm
Hey there...
I'm in the middle of doing up my mini, and after bleeding the brakes several times, the pedal still feels spongy.
I've noticed that bubbles appear in the reservoir if i pump the pedal a couple of times. (i left it a day between noticing the bubbles and bleeding to get rid of them)
Does the master cylinder need overhauling? if so, the master cylinder matches none of the pictures i've seen in books/on the web... which repair kit do i need?
PostPosted: Tue Nov 15, 2005 10:13 pm
Hi Si, welcome to ausmini.
I can't tell from the photos if it is stuffed or not, but highly suggest either fitting a new
cylinder or reconditioned one. You don't want to finish the project and have
something go wrong later.
PostPosted: Tue Nov 15, 2005 10:16 pm
Looks like its been there a while, if the rust on the nut is any indication.
Have you checked for leaky wheel cylinders? They can let air back in, and as the master cylinder is at the top, thats where you will eventually see it. Check them, too.
PostPosted: Tue Nov 15, 2005 10:21 pm
I've put a new set of wheel cylinders, hoses and a new pressure limiting valve. The rear pipes are fine, though i havent taken the front ones off to check them.
Thanks for the welcome, harley. my first post being a question feels a bit wrong, i feel i should have helped some other people first :)
PostPosted: Tue Nov 15, 2005 10:25 pm
Nah, we don't get too formal round here.
Just put a pic of your car in the gallery and you're in. :D
PostPosted: Tue Nov 15, 2005 10:28 pm
I'd be taking off the Master, and getting it Stainless Steel sleeved at the same time.
That way, it will never need to be rebuilt again. Well worth the hassle.
Just have 'fun' removing the pin from the MC under the dashboard :lol: One of the worst jobs on a Mini. Throw away the split pins, and put some 'R' clips back in. much easier. If you can, get a new clevice pin, too. This takes away much of the slop in the pedal-to-master. :wink:
PostPosted: Wed Nov 16, 2005 4:33 am
if you do decide to rekit the MC get a quite first and compare that with a new MC. could be cheaper.... businesses that sell are listed in the how to section :wink:
Aaron
PostPosted: Wed Nov 16, 2005 10:25 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
Si could you also fill in your profile for the area your ie melb syd adel brisvagus
just makes it easier for us to help you
makka
PostPosted: Wed Nov 16, 2005 11:31 am
i need to do this at some point.... :cry: might just turn the car upside down so i don't need to work on my head. ;)
PostPosted: Wed Nov 16, 2005 11:48 am
clevis pins a 5 minute job. seat out long nose pliers, steady handy. done :wink:
Aaron
PostPosted: Wed Nov 16, 2005 11:58 am
additional to the Wheel Cylinders..that you have replaced a another place to check for leakage is on the Pedal..Some time if the the Master Cylinder is leaking it will run down the Brake pedal :wink:
Users browsing this forum: Steam and 77 guests
