It is currently Tue Jul 22, 2025 3:19 pm
PostPosted: Thu Nov 24, 2005 8:34 pm
Anyone know if it's possible to get a replacement for the sensor and the pipe attached to it, for a mechanical specometer water temp guage? I managed to snap the pipe.. I tried Repco but they reckon you have to replace the whole guage. Pain in the ass $50 just cause the little pipe broke. :(
PostPosted: Fri Nov 25, 2005 9:40 am
Unfortunately you will need to get a new gauge as they are one unit & if the pipe is stuffed the gauge won't work.
DIFFERENCE BETWEEN A MINI & ANY OTHER CAR?
WHEN U PULL INTO A SERVO U FILL UP WITH OIL & CHECK THE PETROL.
PostPosted: Fri Nov 25, 2005 6:53 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
some instrament places can fix it but it could costya more than the gauge is worth
makka
PostPosted: Sat Nov 26, 2005 8:06 am
Concur with Makka - the tube is filled with ether - very very flammable and is a gas at room temperature hence would be impossible to refill unless in space!. Repco occaisionally have Speco on special for $29 dollars so replace the guage - I reckon it would cost you an arm and a leg to get the tube repaired.
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Sat Nov 26, 2005 8:32 am
i had a smiths temp(mechanical) guage repaired, cost me $150 to have the new sender fitted with new ether, serviced and calibrated. It's cheaper to buy a new one, unless it's hard to find.
aaron
PostPosted: Sat Nov 26, 2005 2:07 pm
Yep I'll probably have to buy a new one.. I was just hoping Speco sold these as replacements.
Users browsing this forum: Barkfast and 88 guests
