It is currently Wed Aug 20, 2025 8:35 pm
Post new topic Reply to topic  [ 265 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17, 18  Next
PostPosted: Sun Nov 27, 2005 9:28 pm
willy loves the Cooper S he just cant get enough.. :P
PostPosted: Mon Nov 28, 2005 9:28 am
yeah i think a crash repairer would know better :roll:
PostPosted: Mon Nov 28, 2005 7:18 pm
Firstly, a brake fluid does not ETCH like proper paint stripper does.
Secondly, scraping is the first step to paint stripping.
Thirdly, please don't comment on what the "hard" way is.
That is all.
PostPosted: Mon Nov 28, 2005 7:57 pm
That is all.
erection,
its not even that hard to strip the paint back, did the roof in about an hour,
guess ur stamina isnt as high as south aussies, meeni :wink:
Nigel Morton/ Team Brickworx
never late in a 998
PostPosted: Mon Nov 28, 2005 8:16 pm
Meeni, willy is right there but if really want to use brake fluid make sure you treat the metal. By using the metal treatment stuff the metal gets a phosphate or phosphorus (i am no chemistry wiz) coating this protects and etches the surface.
also make sure you use an etch primer not a filler primer that was my mistake :oops: if you still want to use the easier way make sure you use the kill rust primer which contains the metal treatment- it is very expensive in cans so just buy the metal treatment it is $15 for 4 litres and use your decent etch primers.
by the way if you continue to use the brake fluid way, use thinners or turps mixed with the brake fluid as this rips off the paint faster. lately i have been stripping back my minor and have found that the best way is to strip the panel with paint stripper, brake fluid worked but it was alot messier- it doesnt stick to the panel and you tend to waste more than you use and you have to buy the metal treatment.
your best bet is stripper and elbow grease. :wink: i still treat the metal though but i am weird! :lol:
-matt
PostPosted: Mon Nov 28, 2005 8:20 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
the easiest way is a grinder with a wire wheel just watch for flyin metal ....willy you seen the shell in my shed that took me 30 mins to do
just dont push hard it will heat and warp the metal
makka
PostPosted: Mon Nov 28, 2005 8:22 pm
makka
Yeah hehe... its a quick way.
And easiest way.
But still not the "best".
PostPosted: Mon Nov 28, 2005 8:23 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
hmmmm no sore hands paint come off easy did not raise a sweet doing itseams the best way to me :twisted:
makka
PostPosted: Mon Nov 28, 2005 11:32 pm
i tried a wire wheel, and did not find it easy at all :?
PostPosted: Tue Nov 29, 2005 2:34 am
Mien
At the risk of sounding stupid and newbyish, would the wire wheel and an angle grinder do terrible things to the seams if you get too close? What is the best way of removing paint near the seams?
PostPosted: Tue Nov 29, 2005 11:12 am
paint stripper and sand paper is what i have used near seams
matt
PostPosted: Tue Nov 29, 2005 11:30 am
im gonna steal willys topic :P
wat does everything think is the best thing to do,
down to bare metal,
or just sand the top layer off a bit,
this is for me, a home job, dont want to pay a s*** load of money,
but would like a half decent job
cheers bige,
never late in a 998
PostPosted: Tue Nov 29, 2005 11:35 am
where there is rust go down to bare metal, but where the panel seems fine there is no need
matt
PostPosted: Tue Nov 29, 2005 11:43 am
yeah ive (me and dad) repaired all the rust, new panels etc,
so it bare metal in some places already,
so just sand the other parts down a bit n go for it,
is that wat ur saying?
just need to be sure,
never late in a 998
PostPosted: Tue Nov 29, 2005 11:50 am
you will get a better finish if you sand the whole lot down to bare metal, if you have the time do it that way- you use a little more effort and i think it will look the goods! you can just sand it all to a LEVEL finish but you dont want to have a horrible edge were the sanded meets the bare metal.
see what others think before you start- are you respraying the whole car or just a panel or two? if it is just a panel dont bother getting it to bare metal apart from where the rust was/is
if you are doing the whole car just strip it and primer the whole lot then you have a consistant finish through out- i reckon
matt
Users browsing this forum: phillb and 162 guests
