It is currently Tue Jul 29, 2025 1:08 am
PostPosted: Tue Dec 06, 2005 4:35 pm
Try getting a small cold chisel and hammer and gently hitting it against the shoulder of the oil filter,in the right direction ( anticlock wise). Have had to do this with stuborn filters before, be carefull not to damage the housing. Normally I just use my leather belt and this works ok for the not so stuborn ones.
Cheers Craig :)
PostPosted: Tue Dec 06, 2005 7:01 pm
These things these days are made from very thin (Chinese/Korean) steel. If you put a strap clamp on they often just collapse in and the clamp slips.
Hint: Put the strap right at the top ON the seam, it is much stronger there.
Or do what I did recently- go buy a 3 finger swivelling one, they work great and grab ANY size filter. :wink:
PostPosted: Tue Dec 06, 2005 7:08 pm
thanks for all the advice guys!
i have a 3 finger swivel thing.. but it is still hard make it budge....
And in the end....
Gaf is the HERO!
and he used the screw driver technique.. he he he
thanks gaf.. you're a legend.. and I an happy again
8)
PostPosted: Wed Dec 07, 2005 8:27 am
Glad to hear that all is well! Hope he oiled the rubber ring this time :wink:
PostPosted: Wed Dec 07, 2005 8:58 am
Its off
Have you cleaned up the terminals on the Dizzy cap Em?
And bling (well atleast clean) that dash Pot/Carby also :wink:
PostPosted: Wed Dec 07, 2005 11:40 am
h0nk wrote:
stick a bunger in there.. light the fuse, stand back, and the oil filter should come off nicely by it's self
coming from a bloke in redfern i find that rather disturbing :P
good work mr gaf :wink:
Inconspicuously Conspicuous
PostPosted: Wed Dec 07, 2005 11:46 am
on the topic of oil filters,im about to do my first oil change,iv got a ryko filter on at the moment are westfield filters anygood
PostPosted: Wed Dec 07, 2005 4:18 pm
I've never heard of westfield?
Personally I have only ever used, Valvoline, Ryco, Coopers...
PostPosted: Wed Dec 07, 2005 4:46 pm
i know it has nothing to do with it but it feels right getting a cooper one
ook!
69 mini k
PostPosted: Wed Dec 07, 2005 8:54 pm
I got a 'Purolator' oil dilter the other week.
And yes, the filter was waaaay too bloody tight. I ended up using a screwbie in the bottom corner of the filter, and chiselling it off that way. Why do people insist on doing them up that tight? I only ever just let the seal touch, then go about another third of a turn. I haven't had one leak yet. :wink:
PostPosted: Wed Dec 07, 2005 9:57 pm
hahaha..
yes gaf, i cleaned the terminals..
but i am still working on the carby and the clogged up bogged up air filter :lol:
i will get there eventually....
you're all about bling gaf..
and yes chong, I oiled the rubber thing!!
i didnt think brands mattered... as long as they fit :!:
 Post subject: oil filter
PostPosted: Wed Dec 07, 2005 10:14 pm
Best bet would be to go buy a 3 legged filter remover, the ones that can take a 3/8th drive ratchet or use a spanner on the end of it and the more you turn it the more it grips, i've found these were the only type that would remove the filter on my old van.
I bought a Kinchrome one for about $18.00 of our tool van guy but you should be able to get one from Repco or a tool outlet locally.
