It is currently Thu Aug 21, 2025 1:08 pm
PostPosted: Tue Jan 03, 2006 1:10 am
ok i went to check my oil and my dipstick is stuck? i tried using my 21inch cannons to pull it out but i didnt want to break it... tried puttin oil on it to lube it but it still wont come? anyone had this problem before? know wat to do?
PostPosted: Tue Jan 03, 2006 4:26 am
Never had or heard of that problem before.. You'd think with all the oil in there it would be constantly lubricated... have you tried grabbing it and turning as you pull? Vice grips? You could drill the head off the damn thing.. worst case you'll be looking at getting a new dipstick. Shouldn't cost too much to replace.
PostPosted: Tue Jan 03, 2006 5:49 am
Yeah you won't break it, dipstick tube might come out too, but no big deal.
PostPosted: Tue Jan 03, 2006 8:55 am
wonder what dipstick put it in too tight!!!
bahahah :D :D :D
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Tue Jan 03, 2006 11:41 am
LOL.
take GT1310's lead and totaly rebuild you motor with all BLING stuff
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Tue Jan 03, 2006 3:27 pm
Hmmm, Crank hit the dipstick? :shock:
PostPosted: Tue Jan 03, 2006 3:43 pm
CLUBMAN wrote:
LOL.
Nods got home and found more parts on my door :? :shock:
PostPosted: Tue Jan 03, 2006 3:50 pm
did someone put it in the wrong way and manage to lodge it?
how about trying to pull it out when the car is cold
Inconspicuously Conspicuous
 Post subject: Nah..
That would be something to see...
I was thinking that it could be the little section that is pressed out longitudinally to make three springy interference fit things ....may have brokeddead :cry:
PostPosted: Tue Jan 03, 2006 6:14 pm
Crank is normally an awful long way from the dipstick... would need to be in a couple of pieces to hit it!! :lol:
I would put vice grips around the dipstick tube, pull the lot out... :wink:
 Post subject: Dip Stick stuck.
PostPosted: Tue Jan 03, 2006 7:55 pm
I told you to get a longer one as it wasn't reaching the oil any more. You shouldn't have used the hammer to Drive it down further to reach the oil though ! I have never seen this happen.
PostPosted: Fri Jan 06, 2006 5:38 pm
Dude, you have BIG arms if they are 21inch...wholly jesus i wouldnt want to meet you in a dark alley
Mini - The Wizardry on Wheels!
