When I imported a car from Hong Kong (the big blue mistake
) into Qld as a 15 year rule personal import I had to get it compliance checked by a modification engineer. He checked for ADR compliance. Seat belts, child seat anchorages, cat conv, door bars AS or E marked lights & tyres etc. When happy (that I'd poured far more into the car than it was worth) He riveted on a blue plate (QLD transport mod plate). I then got a roadworthy (safety certificate in Qld t'port terms) and showed up to the DOT to register it. They wanted, DOTARS import approval papers, blue plate paperwork and roadworthy plus another wad of cash and hey ho the car was legal.
A 1994 mini should have the following for it to be legit in Qld as of 5 years ago:
> A new compliance plate from the importer with a VIN number starting with 1MPORT
> A rego sticker that says it is a 1994 mini and correctly identifies the above VIN number
> Number plates that have the same rego as the sticker.
> Side intrusion door bars
> Two child seat anchorages fitted to the parcel shelf (just the captive nuts, bolts and clip not mandatory)
> Restricted fuel filler neck for unleaded
> A tyre placard stating tyre sizes and recommended pressures
> A sticker of some sort near the filler saying similar to "unleaded fuel only"
> A cat converter.
> A tune-up sticker under the bonnet stating something like "not adjustable" or "CO = ??% at 5deg at 800 rpm" whatever the standard is for the car.
> Inertia reeler seat belts in all 4 seats.
> seat belts marked with the AS label or E-marked
> head lights, tail lights and side lights all AS or E marked
> side mounted indicator repeaters.
> Flat, not convex driver's side door or wing mirror. Same for internal rear view mirror.
> if the passenger side mirror is convex it must be labeled with "objects in mirror are closer..." blurb.
> Tyres marked with some form of international standard logo. Definately not Jap legal re-treads.
> heated rear window.
> windscreen demister
Thats about it. Of course most of the blue plate guys let one or two items slide and some of the importers were DODGY, hence the RAWS scheme crap we've got now.
Happy inspecting. M
