It is currently Tue Jul 22, 2025 1:54 am
 Post subject: compression value
PostPosted: Thu Jan 12, 2006 5:02 pm
Does anyone know the compression value of a 998 engine.
I'm getting 71 psi on the first stroke and a final reading of 138 psi on all the cylinders.
thanks Felix
1966 mustang coupe 289 auto
1970 mgb roadster auto
1970 cooper S mk2
1976 mini S
1964 wolseley 24/80
http://s160.photobucket.com/albums/t173/1966mini/
PostPosted: Thu Jan 12, 2006 6:46 pm
That's a bit low.....
JAM was getting 165 prior to recent rebuild.
My $100 special 77 Clubby is getting 155 and runs well enough.
Website: www.justanothermini.com
PostPosted: Thu Jan 12, 2006 7:03 pm
but at least it is worn out evenly
PostPosted: Thu Jan 12, 2006 8:01 pm
My 1100 is getting 125 on all four. I know it is low but at least it is constant (and has been for seven years)
PostPosted: Fri Jan 13, 2006 5:17 am
Do you guys recommend I get the head reco and check the pistons
or just leave it as is.
Felix
1970 cooper S mk2
1976 mini S
1964 wolseley 24/80
PostPosted: Fri Jan 13, 2006 6:20 am
the compression values i obtained were taken with the engine cold as there is no manifold on the engine.would a cold engine cause the low values
1970 cooper S mk2
1976 mini S
1964 wolseley 24/80
PostPosted: Fri Jan 13, 2006 7:37 am
Yes, I believe you are supposed to do it WARM.
PostPosted: Fri Jan 13, 2006 9:07 am
thanks all,
i will do the compression check again once i change the side cover gaskets and exhaust/inlet manifold gaskets.
next job on the 76 clubman S is welding a patch on the drivers side kick panel and getting seats re upholstered.
Felix
1970 cooper S mk2
1976 mini S
1964 wolseley 24/80
PostPosted: Fri Jan 13, 2006 9:21 am
Felix
Go see my trimmer. Might be a bit of a hike for you...but he does have all the original clubby cloth (no more black though :P )
PostPosted: Fri Jan 13, 2006 1:51 pm
Hi Anton,
can you give me the details of your trimmer.
I only need the front seats redone in the original bone coloured material
thanks Felix
1970 cooper S mk2
1976 mini S
1964 wolseley 24/80
PostPosted: Fri Jan 13, 2006 2:12 pm
done :wink:
PostPosted: Fri Jan 13, 2006 7:22 pm
A cold engine will give higher values ...so when hot it will be significantly lower l
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Fri Jan 13, 2006 9:31 pm
A relativly chick check is to put a small bit of machine oil down the plug hole and do a wet test, if compression improves, shows a very worn engine.
If in doubt ask
PostPosted: Fri Jan 13, 2006 9:37 pm
i have high compression on mine 210 psi :P
