It is currently Mon Jul 21, 2025 9:40 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
 Post subject: Re: Cold carby...huh?
PostPosted: Thu Jan 12, 2006 6:50 pm
It sounds like your carbys are out of sync at idle and one carby is doing squat at the other is flowing twice the air that it should. If you re-set the idle (just open the screw on the lazy carb and back off the screw on the cold one) it should be fine.
Precisely what I did this arvo :wink: PLUS I bought a new pair of BLUE springs for the carbs. Just in case.....
Website: www.justanothermini.com
PostPosted: Thu Jan 12, 2006 6:58 pm
go find your 1.5 su borrow its needle and use the hif :) sorted
PostPosted: Thu Jan 12, 2006 7:04 pm
It is a standard 998cc Clubby needle.....it would be too lean, just like the one in the HIF.
Speaking of standard....I found out this arvo that JAM's HS2 needles (AN) are standard 1098 Sprite needles :lol: No wonder it's down on power!
Users browsing this forum: Phil 850 and 79 guests
