It is currently Tue Jul 22, 2025 7:36 am
PostPosted: Sun Dec 11, 2005 7:06 pm
I have read once before that tachos from points and elec ignition cars were not compatible.
Now that i have honda electronic ignition, will it be a problem using an old smiths tacho, or any tacho?
PostPosted: Sun Dec 11, 2005 7:46 pm
I'm using a Smiths 8000 tacho on one Pulsar dizzy, and a Veglia Borletti (ex Fiat 124BC coupe) on another. No problem. 8)
PostPosted: Sun Dec 11, 2005 8:34 pm
Yeap, the stock smiths tacho in my clubby works fine with the electronic pulsar one :)
PostPosted: Mon Dec 12, 2005 3:55 am
Doc are't the loop pickup style tachos incompadre with leccy ign?
PostPosted: Mon Dec 12, 2005 6:31 am
Yes, that's what Barney has I think.
Coil operation is the same, it's just the switching of primary current that is electronic.
PostPosted: Mon Dec 12, 2005 6:47 am
Dont ya just put a resistor or something inline to the tach :? cant remember but have seen something about it before
PostPosted: Mon Dec 12, 2005 6:56 am
Clubbies have a loop type tacho and they do work with Pulsar or Honda dizzy.
They are just wired in series with primary circuit.
PostPosted: Mon Dec 12, 2005 7:33 am
Ok ok so more in detail - what needs to be done to be able to run the Smiths type loop type with elec ignition? Or what can be done?
PostPosted: Mon Dec 12, 2005 7:41 am
On Josh's car, when we fitted a Pulsar, we did nothing- it uses the standard Clubby wiring. 8)
PostPosted: Wed Jan 18, 2006 8:25 pm
resident alien
resident alien
Ok so the standard Lucas dizzy is NOT electronic?
PostPosted: Wed Jan 18, 2006 8:33 pm
Correct. Not the antique ones on Oz made Minis, anyway.
PostPosted: Wed Jan 18, 2006 8:42 pm
resident alien
resident alien
Well it looks like I'll have to get myself a pulsar dizzy to use with my new tacho then :wink: :)
PostPosted: Wed Jan 18, 2006 8:52 pm
Marvin, no no no.. you can use a Standard Dizzy.. no problem, DOc was just saying it ALSO works woth thepulsar ones.,....
The Tach side of things is exactly the same, but the pulsar Dizzy replaces the points with a doohickie ....
the tach stays the same....
and for the record, I've got a Pulsar Dizzy, and a Veglia Tach ....... (Same as Haha)
J
PostPosted: Wed Jan 18, 2006 9:00 pm
resident alien
resident alien
Yes I understand you can use the current tacho with a pulsar dizzy but I just bought a Speco tacho and it says elec ignition so therefore I need to get a pulsar dizzy. It came with a diode to be used with points ignition but I may aswell just get a pulsar one anyway 'cos of all the other good reasons to have one
Users browsing this forum: Bing [Bot] and 88 guests
