It is currently Sun Aug 03, 2025 12:26 am
 Post subject: New wheel bearing?
PostPosted: Thu Jan 19, 2006 2:13 pm
I just replaced a rear wheel bearing on my clubby because it seemed to have movement where the other side didn't. Problem is it still has movement with the
new bearing. I can't tighten the nut any more without damaging something.
The nut is as tight as I can get it which seems strange, I thought it would bind the bearing if too tight. :roll:
Could it be that the axle itself is worn?
Anybody had this problem before?
PostPosted: Thu Jan 19, 2006 3:26 pm
Which direction is the movement in?
Along the shaft or against it?
PostPosted: Thu Jan 19, 2006 4:00 pm
I seem to remember two types of rear wheel bearing being available ?
One designed for Cooper is slightly wider or something and causes movement if used in different drum setup and needs to be machined down if you happen to use that one.
Dont quote me on that though....it may be totally wrong.
No more Minis!......For now.
PostPosted: Thu Jan 19, 2006 4:05 pm
Have you checked that it is not the swing arm bushes and roller bearings gone :?:
Roads need more corners
PostPosted: Thu Jan 19, 2006 8:35 pm
It's definately not the swing arm I can feel the movement in the hub.
The movement isn't along the axle, if I grab both sides of the hub the
movement seems to be against the axle.
