It is currently Sat Jul 19, 2025 2:02 pm
 Post subject: age of mini
PostPosted: Wed Sep 15, 2004 5:05 pm
I too am trying to find out what year my mini was made.I've looked in all the places you guys have mentioned and the only date is on the wiper motor (10 64) but this culd have been changed.The engine has been upgraded to a 1100 so those dates are no good.
I know it was built between 1965 and 1969 by the body type number.
B :twisted body type number is YMA2S2 and body number is 23405.
Any help would be appreciated.
:shock:
PostPosted: Wed Sep 15, 2004 5:23 pm
this is my only inside pic
http://hoggle.e-access.com.au/HomePage/Astro/inside.jpg
which type is this?
and the engine stuff doesn't matter as i have a 998.. ;)
BTW
In the 28 years of leyland oz
176,284 mini maded
=6295 per year
the morris was out of production in 67 which means that only 44065 850's were made which means my calculations are fu*ked so ill just say it's a 64 ;)
 Post subject: Re: age of mini
PostPosted: Wed Sep 15, 2004 5:24 pm
:shock:
Check for a date code on the boot lock too... :wink:
PostPosted: Wed Sep 15, 2004 11:30 pm
The body numbers start at 501, so the first car off the line is #501 not #1
You have to remember to subtract 500 off you body number to get the cars actual build number.
Also, if you check the dates on the parts in the car remember that these parts may have sat around for a couple of months before they were fitted to cars. My Cooper S has a wiper motor from early 68 and some other parts from mid 68 and one part from 11/67. So it would have been made sometime after the latest date (unless that part was changed later)
I have the build numbers for the 1100s but not minis :cry:
PostPosted: Thu Sep 16, 2004 6:27 am
Geez, autos must be lots rarer than Cooper S's then, mine (3/1970) is #1385 so there might have been only around 1,000 (or less) of 'em made!
Pity they're not worth similar $$$$$.. :cry:
PostPosted: Thu Sep 16, 2004 4:30 pm
doc put a gold bar in the back seat
or your edited version of David Vizards book and you get the $$ for it
Inconspicuously Conspicuous
PostPosted: Thu Sep 16, 2004 5:45 pm
They must have only made a few 850 engined cars after they got rid of the sliding windows too. My Mini Minor is supposedly a 66, but the body number is 1035 (from memory). According to wombats calcs, this would make it the 535th car 8)
I also threw away a 1961 850 shell that was horribly rusted out in the boot and A panels about 15 years ago. If i knew then what i know now i would not have done it, even if the engine was a 1098 clubbie job, but the pressure was on because my parents were moving house and there was no room for it :cry: . At least i still have the two piece roof lining from it, and if you are very nice and offer me lots of money i may even sell to you.
PostPosted: Thu Sep 16, 2004 9:23 pm
The rarest mini I have seen is a grubby white Clubman in a wreckers that when we pulled the back seat out it had written behind the seat "Last Zetland Mini" :shock:
PostPosted: Thu Sep 16, 2004 9:24 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
did you take the shell ??
,akka
PostPosted: Thu Sep 16, 2004 9:31 pm
hey just been wonderin......what models had sliding windows? and are there many left? or are they "collectors items" these days?
sorry for the hijack.....i'll be quick :)
play 3d car games for free
PostPosted: Thu Sep 16, 2004 9:40 pm
Nah, full of rust and had already had most of the good stuff pinched.
In Aus the 850 and the Cooper had sliding windows and the Panel van.
In the UK all minis up to the MK 2 (about 69?)
PostPosted: Thu Sep 16, 2004 9:56 pm
thanks dude......
are there many left about? or have they all been converted to wind-ups? and are they considered valuable?
-jimmy
PostPosted: Thu Sep 16, 2004 10:23 pm
Didn't they then move the last Mini production to Enfield where the Mokes were already??
PostPosted: Thu Sep 16, 2004 11:05 pm
Yep after Zetland finished they went to Enfield.
I think it was a 73 or 74 car.
 Post subject: build date
PostPosted: Fri Sep 17, 2004 9:13 am
drmini,
i have removed the boot lock completely and there is no date there either
