It is currently Wed Jul 23, 2025 10:59 pm
PostPosted: Fri Feb 10, 2006 12:32 pm
I need to replace my bleeder nipple off my 7.5 disks, as the current one is rounded off. I know its a 3/8 head on it, just wondering if anyone knows the length, thread size as the fellas at the brake place want me to bring in a sample. But this would mean i cant drive there and would have to drain all the fluid out too.
any one got a photo of one off the brakes?
shane
PostPosted: Fri Feb 10, 2006 1:18 pm
I have a set at home will look at them tonight and get bach to you.
Pete
PostPosted: Fri Feb 10, 2006 1:45 pm
Make sure you measure them when cold! :D
1971 Clubman GT - Jet Red
1980 Mini 1000 - Bold As Brass
1967 Riley Elf - Red/White
2002 MINI Cooper - BRG/White
2005 MINI Cooper - BRG/White
2022 MINI Cooper SE - BRG/White
PostPosted: Fri Feb 10, 2006 2:12 pm
thanks fellas!
PostPosted: Fri Feb 10, 2006 3:43 pm
The one's on mine are 3/4 of an inch from start of thread to the tip, and have a 3/8 UNF thread and a 7/16 hex on them. This seems a bit wierd as yours have a 3/8? hex on them!
Pete
PostPosted: Fri Feb 10, 2006 4:52 pm
Why cant you drive the car to the brake place and let them sample the nipple that is already in the caliper. One look and they will know what size it is and if they have one in stock then they will replace it. Get them to replace the other side as well.
You may loose a small bit of brake fluid and they will probably want to give the disks a quick bleed to replace the fluid but this is something that should be done on a bimonthly basis anyway.
You watch any racing team - amateur or pro, the never go onto the track without fresh fluid in the calipers. Bleed them everytime they go onto the track.
PostPosted: Fri Feb 10, 2006 10:22 pm
went there today, they would,nt even look at the one in the car. They needed it out for them to compare. Lazy bastards is all i got to say. And they were so helpful last time. Anyone know of a brake joint around this neck of the woods open on a saturday? Karcraft also told me i would not be able to find a new nipple for them anywhere. Has anyone else found them before? Thanks for the measurements Pete, maybe i've got my numbers muddled up, will double check tomorrow.
PostPosted: Fri Feb 10, 2006 10:40 pm
Slow-Po
Chop, if you need a hand or a lift tomorrow (Sat), just yell out.
PostPosted: Fri Feb 10, 2006 10:46 pm
cheers mate! Has h0nk got disk brakes? might swap my bleed nipple with his! :lol: :lol:
PostPosted: Fri Feb 10, 2006 10:50 pm
Slow-Po
:lol: :lol: He'll come running out in full riot gear. :lol: :lol:
PostPosted: Fri Feb 10, 2006 10:53 pm
hey you have disks too! :lol: :lol:
PostPosted: Fri Feb 10, 2006 10:57 pm
Slow-Po
And a shooter's licence - the car in actually right in the middle of my cross hairs right now! :lol: :lol:
Users browsing this forum: No registered users and 117 guests
