It is currently Tue Aug 05, 2025 2:52 am
 Post subject: GR Manifolds
PostPosted: Thu Feb 16, 2006 2:49 pm
Question... i jus got a GRE manifold for my HIF44 but there is a problem... there is no where to put a bracket to hold the accelerator cable in place?
does anyone have pic of one with a bracket? or do i even need the bracket?
thanks
PostPosted: Thu Feb 16, 2006 3:07 pm
I have a GR manifold and the cables go through a bracket that sits between the carby and the manifold. see pic.
Nothing is attached to the manifold.
Daily Driver - Yellow Devil 76 Clubman
Restoration Project - Primer grey 66 Morris Mini Deluxe
 Post subject: .
PostPosted: Thu Feb 16, 2006 5:57 pm
where would i be able to get one of these brackets?
PostPosted: Thu Feb 16, 2006 6:12 pm
This is what you need.
Can get them from
www.minis.com.au
or
www.minisport.com.au
Pete
PostPosted: Fri Feb 24, 2006 5:39 pm
ok i got one but i dont see how the accel cable will be attached to it?
PostPosted: Fri Feb 24, 2006 6:07 pm
You also need a HIF style accelerator cable - I am sure others can be made to fit but the HIF one is just sooo easy.
It has a nylon end piece molded into which clips onto the throttle sandwhich bracket.
The HIF throttle cable is normally yellow as in the previous photo
PostPosted: Fri Feb 24, 2006 6:43 pm
use the standard Mini bracket, just as Simple Simon has done. Then you can use the same choke and accelerator cable. Simple really :lol:
Website: www.justanothermini.com
PostPosted: Fri Feb 24, 2006 9:43 pm
how much are those GR manifolds going for these days?
PostPosted: Fri Feb 24, 2006 9:52 pm
Around $200 I think. :wink:
Users browsing this forum: Bing [Bot] and 94 guests
