It is currently Sun Aug 10, 2025 7:46 am
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed Mar 01, 2006 9:37 pm
You really should have a look at my Austin Montego. :wink:
Wasn't that a VW based box that fitted on the end of the block, not underneath like a Mini? :?
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Wed Mar 01, 2006 9:53 pm
Sounds good to me, I like VW boxes- I was a VW/Formula Vee mechanic in a previous life.:)
Is it the 3.44 diff thats in the 1275LS and (most) Rovers?
PostPosted: Wed Mar 01, 2006 9:55 pm
3.44 diff was in the 998 Clubbys, and the LS too.
And in the Cooper S & Clubby GT before that.
PostPosted: Wed Mar 01, 2006 9:58 pm
Whats in the Rovers then?
All these numbers, i've forgotten whats in what :lol:
PostPosted: Wed Mar 01, 2006 10:00 pm
Depends which Rover. Some over there had stupid gearing, like a 998 pulling a 2.76... or trying to! :lol:
PostPosted: Wed Mar 01, 2006 10:06 pm
My car @ 100km sits @ ~3500rpm...what theoretical ratio is that?
PostPosted: Thu Mar 02, 2006 7:16 am
Have a look at the tech section of the Hot Bricks SA site. It gives you a good approximation of speeds for revs for a range of diffs and wheel sizes. Would paste it but was too big for page.
www.hotbricks.org.au
PostPosted: Thu Mar 02, 2006 6:03 pm
Sounds good to me, I need a Formula Vee mechanic. :lol:
The Montego has a VW Golf 4 speed bolted onto the end of the 1275. It is a fairly easy swap for the 5 speed.
Hey Doc, I found a Tempo Matador the other day, ever seen one of them?
PostPosted: Thu Mar 02, 2006 6:07 pm
Ummmmm .... NO, I don't think so. Not a Rambler Matador? :?
PostPosted: Thu Mar 02, 2006 7:33 pm
Not a Rambler, a Tempo. It is a German light truck with a VW Beetle engine and ....... Front Wheel Drive! :shock: It is a lot like a Kombi with the engine under the front seat!
Take a look at http://www.vwtrendsweb.com/features/0108vwt_tempo/
PostPosted: Thu Mar 02, 2006 7:52 pm
I think just forget about wherever you found it , it looks wierd . SO sort of a reverse kombi , front engined and front wheel drive ?
PostPosted: Thu Mar 02, 2006 8:05 pm
They were the 998 economy engines. :lol:
Josh... yours would be 3.44 like mine. Thats 3500rpm with those BIG tyres? 3600rpm with your normal run of the mill 12" tyres would be 100kph.
PostPosted: Thu Mar 02, 2006 8:32 pm
mine sits at 3600rpm @ 90km/h and i do 100km a day at that speed, seems fine to me, good for when you need to overtake aswell
PostPosted: Fri Mar 03, 2006 4:04 pm
With my 12's pre big tires, it sat around 4000rpm @ 100km/h..
