It is currently Sun Aug 17, 2025 11:46 pm
 Post subject: carb id
PostPosted: Mon Mar 06, 2006 3:08 pm
picture coming
Could anyone identify model of my su carb
Thanks
1977 Clubman
PostPosted: Mon Mar 06, 2006 3:10 pm
1977 Clubman
PostPosted: Mon Mar 06, 2006 3:12 pm
While i'm here what about cylinder head - can it be identified from this pic
Thanks
1977 Clubman
PostPosted: Mon Mar 06, 2006 4:16 pm
Carb I think is the basic , late 70's 1 1/2 (h number I don't know off hand) and the head is 78ish pollution head with the threaded holes for the pollution control airpump . No idea on valve sizes or which head exactly , if you take the rocker cover off somewhere on the casting there will be a 12G number and we can tell more from that .
PostPosted: Mon Mar 06, 2006 4:26 pm
Pollution (aka `smog') heads-
smallbores all had 1.090" inlets and 1.000" exhausts,
1275s all had 1.313" inlets and 1.156" exhausts (head casting # 12G1316).
PostPosted: Mon Mar 06, 2006 4:30 pm
yep....what he said.
Standard HS4 carb (1 1/2") and standard 998 'SMOG' head.
BTW......aren't there any grub screws in those holes? If not, how does it run without them? :?
Website: www.justanothermini.com
Thanks
1977 Clubman
PostPosted: Mon Mar 06, 2006 4:31 pm
What holes ?
1977 Clubman
PostPosted: Mon Mar 06, 2006 4:36 pm
The 4 holes in the front of the head below the spark plugs , these were used to allow air into the exhaust ports and therefore dilute the exhaust so there was lass percentage of pollution being produced (Yeah , they were clutching at straws ...) . These should be blocked , normally they have grub screws in them , otherwise it'll blow exhaust gas out the front and make a lot more noise . Are there any grub screws in them , can't see clear enough from the pics ?
PostPosted: Mon Mar 06, 2006 4:42 pm
No - no grub screws, look like rubber inserts in each hole, a couple have holes in the rubber inserts - is this bad should i put screws in to block the holes ?
1977 Clubman
PostPosted: Mon Mar 06, 2006 4:44 pm
Yeah , put screws or very short bolts into them otherwise you'll be getting a lot of fumes in the engine bay coming back into the cabin .
PostPosted: Mon Mar 06, 2006 4:46 pm
ok thanks - will this make any difference to the performance ?
1977 Clubman
PostPosted: Mon Mar 06, 2006 4:49 pm
most likely not , after all , all you'll be doing is blocking some potentially leaking exhaust gases .
PostPosted: Mon Mar 06, 2006 4:51 pm
7/16 UNF x 3/8"
4 off
Approx $4 each :shock:
PostPosted: Mon Mar 06, 2006 4:54 pm
Thanks guys
You learn something evry day :)
1977 Clubman
Users browsing this forum: No registered users and 313 guests
