It is currently Sun Aug 17, 2025 12:45 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sun Mar 19, 2006 7:11 pm
Is it financially viable ; IE does it stomp the crap through a 5 port head that has been ported a fair bit?
PostPosted: Sun Mar 19, 2006 7:13 pm
It has something bigass 5 ports do not, it's called torque. Sure U can coax 150-160HP from a 5 port, but it won't last, or be street drivable- you need big cams to get this power, with a 5 port..
Last edited by drmini in aust on Sun Mar 19, 2006 7:16 pm, edited 1 time in total.
PostPosted: Sun Mar 19, 2006 7:14 pm
i would have thought so, but i would also think that dur to he head being more efficient it would make for not only more power but probably a nicer, smoother drive? less cam required to make the bhp if you get my idea?
PostPosted: Sun Mar 19, 2006 7:15 pm
Yes that is the idea, Dean's was drivable (just) on street at 165HP, it's got a bit tamer cam in now.
PostPosted: Sun Mar 19, 2006 7:17 pm
And out of curiosity, how much would it cost for assembled head, extractors, and carbs.
PostPosted: Sun Mar 19, 2006 7:21 pm
Head comes with all bits, and the header pipes for the 4 port extractors. Just need to weld em. Carb setup- Webers or Dellos bolt on, you supply.
Not sure of exact pricing but cheap compared to Arden 8 port, which I've been told are not real good right now.
PostPosted: Sun Mar 19, 2006 7:35 pm
http://www.minispares.com/Product.aspx?pid=35502
arden head(with guides but no valves) isint cheep at arround $3300 au plus ou need to fiddle with it quite alot.
minisport/akm 7 port is arround $2500 au (bare head)
PLUS SHIPPING
so really there not cheep at all
PostPosted: Sun Mar 19, 2006 7:55 pm
Neither of those heads perform as well as the current Elder does, from what I have heard here.
Arden one is having its port patterns redeveloped now, so they will work like the old ones used to.
PostPosted: Sun Mar 19, 2006 8:25 pm
the arden seems to be tricky to fit too, having to fiddle with the valve gear and push rods, at lest with the elder, as far as i can tell, you can use standard mini setups. i suppose one advantage of the akm is that you can use standard extractors/maniflold gasket, then again, if you can afford the head and the induction, then the extractors shouldnt really concern.
the elder also comes with a cool rocker cover :P
PostPosted: Sun Mar 19, 2006 8:39 pm
Yes the Elder has standard Mini valve layout, funny camlobe assignment not needed. :wink:
Problem on the AKM is they have made the ports setup to bolt Webers on head directly, so the inlet port shapes are weird. And too big, I believe.
PostPosted: Mon Mar 20, 2006 10:30 am
Injection, Will. Go injection. 8)
PostPosted: Mon Mar 20, 2006 10:40 am
ok, elder head is priced at arround $3250, ready to bolt on, plus $325 for extractors, thats a damm good price compared to the price of a bare arden.
PostPosted: Mon Mar 20, 2006 11:23 am
i have been pm'd by a member with a very serious 8 port mini for sale, very well priced, if anyone is interested pm me, and ill put you in touch.
PostPosted: Mon Feb 26, 2007 6:55 pm
Just wanted to bump this thread to say that jbeenz prices seem to still be current, I rang today as I'm seriously looking into this for an injected turbo setup.
PostPosted: Mon Feb 26, 2007 7:18 pm
:D keep us updated, id love to see a boosted 8-porter!
the cool thing about elder is that they will grind/port/chamber the head to your specifications :P
Users browsing this forum: No registered users and 321 guests
