It is currently Thu Jun 26, 2025 5:06 pm
Post new topic Reply to topic  [ 56 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Roundnose conversion ?
PostPosted: Tue Mar 21, 2006 12:03 pm
Die Die Die!!
just a querie bout roundnose engine conversions are theyre any engines that can be used that dont involve body work (not including subframes) being altered?
PostPosted: Tue Mar 21, 2006 12:04 pm
only ones that arent all that wonderful...this applies to clubmans too i believe...by body work we are talking not even the inside walls of the engine bay i am assuming?
Bling me up Scotty!
the swift/cultus gti?
PostPosted: Tue Mar 21, 2006 12:05 pm
still need to cut the crap out of the engine bay walls...
Bling me up Scotty!
PostPosted: Tue Mar 21, 2006 12:09 pm
Die Die Die!!
well yeah.. i guess some engine bay cuting wouldnt be too bad.... but if its avoidable...
PostPosted: Tue Mar 21, 2006 12:12 pm
you could just convert to an a-series :P
Bling me up Scotty!
PostPosted: Tue Mar 21, 2006 12:15 pm
Die Die Die!!
and erm...that means ? ... im looking into conversions that dont involve too much effort (although its still gonne just as much as any conversion) becuase its a heck of a lot easier than working out power steering/ Airconditioning on its own... as well as the fact the a/c costs like $880.. it works out cheaper and something around 1.3/l would be good.. just enough to give commies a little scare..
PostPosted: Tue Mar 21, 2006 12:41 pm
i was kidding
i dont know of any modern engines that are equal in size to or smaller than an a-series (maybe there are some 3cyl ones kicking around that are)...the a-series gb is in its sump...and so that saves ALOT of space...
Bling me up Scotty!
PostPosted: Tue Mar 21, 2006 2:28 pm
Maybe a 3cyl Daihatsu that's pretty small even with the gearbox on the side and the turbo ones make about 100hp fully tricked up...? I wish someone made a V4 FWD engine that would cut down the size a bit.
PostPosted: Tue Mar 21, 2006 2:30 pm
wishin wont make it happen ;)
Bling me up Scotty!
PostPosted: Tue Mar 21, 2006 2:43 pm
early ford capri's, corsairs, saabs and lancias had v4's
PostPosted: Tue Mar 21, 2006 2:45 pm
Maybe use a Suzuki Vitara V6?
Can't think of a smaller readily available V6
PostPosted: Tue Mar 21, 2006 2:52 pm
isnt it nth/sth? i woulda thought the 1.8L mazda 30x motor woulda been yer best bet for a v6 conversion...
as for v4...why bother :P just go in-line 4 and pick something not enormous (<1.6L)...a bit of panel cutting is all part of the fun :)
Bling me up Scotty!
PostPosted: Tue Mar 21, 2006 5:08 pm
Die Die Die!!
hmm ok... whats the stock horse power of an 1100 mini ?
PostPosted: Tue Mar 21, 2006 5:24 pm
50ish at the crank i believe...
Bling me up Scotty!
