It is currently Sun Aug 17, 2025 9:39 am
PostPosted: Fri Mar 24, 2006 9:13 pm
Towards the end of the dim, dark ages of Lucas sealed beam headlights, a couple of French companies, Cibie and Marchal led the way forward with twin globe and twin reflector 7" halogen lights called 'Biodes'.
They were basically a normal halogen low beam light housing within it a smaller high beam driving light. They were all the go for rally cars and still a damn good light. I don't know if they are still available new, but they are worth grabbing if you find a set.
The ones fitted here are Marchal.
Image[/img]
Curly
PostPosted: Fri Mar 24, 2006 9:14 pm
Mini Mad wrote:
xenon produce a lot of heat and i certainly would not trust a set of $1000 globes in some cheap ass taiwan angel eyes :idea:
I was told less heat was produce by them not more. I must look for more info first.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
1970 Mini K, 1380cc, 1.75 HIF SU, 30 70 Cam, 2" Zorts
1969 Mini K, Stock Standard and Orginal. (Slow as Hell)
PostPosted: Fri Mar 24, 2006 9:23 pm
I may be wrong..
One source..:
"The internal quartz arc tube temperature is probably typically around 800 degrees C (1400-1500 degrees F or so). The outer bulb is not this hot, but it is definitely burning hot. The arc tube always has at least some miniscule risk of exploding and should only be operated in a headlight housing or other suitable container. Improper operation increases the risk of bulb explosion."
Taken from here:
http://auto.howstuffworks.com/framed.htm?parent=question387.htm&url=http://www.misty.com/~don/d2.html
But also:
"HID lights actually produce significantly less heat than standard bulbs. These lights can be left on for extended periods of time and not cause problems."
http://www.preciseflight.com/faq-hid.htm
I have the opposite problem, my normal beam is similar to a high beam ... then i have driving lighhts as well.
I get told constantly their to bright , shud i just get a lower wattage globe
PostPosted: Fri Mar 24, 2006 9:24 pm
Can never be too bright, sounds like it's either angled wrong or wired wrong and is always on highbeam..?
PostPosted: Sat Mar 25, 2006 2:37 am
probably angled wrong ... put it this way i have parkers normal high and driving light options
PostPosted: Sat Mar 25, 2006 7:34 am
Slow-Po
www.minitrailers.com sell xenon angel eyes, their FAQs are worth a read. :wink:
http://www.minitrailers.com/angel.htm
PostPosted: Sat Mar 25, 2006 7:44 am
They are not true Xenon gas discharge headlights by the look of it..
PostPosted: Sat Mar 25, 2006 9:49 am
True HID lights require a tranformer as they run 32-36V
Also by law, a vehicle with HID lights must have automatic self levelling
(only found in big, expensive cars like BMW, Merc, etc)
PostPosted: Sun Mar 26, 2006 4:37 pm
Might be a stupid question, but the new convertible has headlights with 2x on them. What are they..?? Double strength headlights?
I have a set of H4's in the garage. They are going on the Clubby when she gets on the road.
Users browsing this forum: No registered users and 402 guests
