It is currently Wed Aug 20, 2025 3:31 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Sun Mar 05, 2006 9:08 pm
To test the master cylinder....
1) Take the bleeder screw out of the slave cyl and stick it into the outlet of the master cylinder.
2) Bleed the master cylinder.
You should have a solid pedal. :wink:
If you have any movement you have a problem with the master cylinder.
PostPosted: Tue Mar 07, 2006 9:53 pm
ok i went and purchased a new slave cylinder got home fitted it and all is now working as it should and the clutch has never felt better
thank you to all the advice
till the next..
Peter.
A almost Bog Stock 1977 LS
1969 morris mini panel van, a work in progress
PostPosted: Tue Mar 07, 2006 11:02 pm
them bloody slaves!
PostPosted: Sat Apr 01, 2006 8:49 am
ok people will some one explain this to me
after all the recent headaches with this damn clutch
it was working fine till this morning get in the car all of about a 1/4 clutch
it has new master cylinder
new slave cylinder
new flexi hose
has been bleed properly
has new clutch and pressure plate
and all of the best mechanical bits i had avalible to me at the time
yours truly frustrated..Peter.
PostPosted: Sat Apr 01, 2006 9:20 am
Just a couple of questions, have you adjusted the 7/16 return stop and do you have a return spring on the the slave cylinder and just one more does the pedaal pump up on the second pump
Jon
PostPosted: Sat Apr 01, 2006 10:42 am
i havent checked the stop this morning as yet and the pedal doesnt seem to improve buy pumping it
will have a good look a little later today
Peter.
Users browsing this forum: Bing [Bot] and 163 guests
