It is currently Fri Jul 18, 2025 9:24 am
 Post subject: Great Responses
PostPosted: Fri Oct 01, 2004 7:43 am
Thx Guys for the info, I'm now in the process of making mine.
PostPosted: Sun Oct 03, 2004 11:10 am
Can you put some pics up if your finished?
i have a van and would be a great tool to add to my collection
PostPosted: Sun Oct 03, 2004 1:34 pm
Fix it before it gets worse.
My son's Clubbie rusted right thru from the top, in the RF corner, it took me about 4 hours to patch weld it. Bastard of a spot to get into without burning the roof lining etc...
doc i think ive got a couple of places up there like that
how do you fix it before it gets worse?
my instinct is that id attack it with a screw driver until i see bare clean metal
and then sand out
rust convert
and paint over
this job would be in the bottom of the gutters, and only about 1cm strip wide
and i'd do it with a little paint brush
Inconspicuously Conspicuous
PostPosted: Sun Oct 03, 2004 5:14 pm
Yeah that method's OK if there's still metal there... The screwdriver went right thru on this one, both above and below the gutter! :shock:
I had to dress it out with the die grinder, then cut and bend 2 thumbnail-sized patches, then MIG weld them in, without setting the hood lining etc afire. Not a nice job.... :x
PostPosted: Sun Oct 03, 2004 5:24 pm
ugh
arent you glad the rust spots werent on top of the fuel tank... or were they?!
PostPosted: Sun Oct 03, 2004 5:42 pm
No this was RH front corner of gutter, above driver's door. Where they all seem to rust first!! At least there's no wiring in there, unlike the LH side... :shock:
PostPosted: Fri Oct 08, 2004 7:09 am
There is a mini van rotisserie on the vmci website if it helps. Might still be for sale as it has been on there for a while. Only for $50.
 Post subject: its sold
PostPosted: Fri Oct 08, 2004 10:21 am
I called him and he had sold it. I have come up with a rotisarrie myself taking into account: Portability, starage ability, stability, adjustable height, and rotational locking. Unfortunatly the ends are "A" type frames and hinder single pass spraying.
PostPosted: Sat Oct 09, 2004 5:55 pm
J_A_M wrote:
hmmmm......is that spray putty I see there on the 850 Kev??? Naughty naughty..... thats cheating! :lol:
what wrong with spray putty? :shock: i was thinking about using it on mine, when the time is right :P
[Maverick] 1971 Mini K
Users browsing this forum: No registered users and 26 guests
